IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
HAS + pivot
With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width. -
Blue light reducer
As we all know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours with a computer screen. This product achieves it by adjusting the monitor's brightness and color temperature through a feature called "blue light reduction" easily accessible through the monitor's OSD menu. -
Overdrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the overdrive feature will eliminate that. -
Speakers
This LED monitor is equipped with two high quality stereo speakers.
- iiyama ProLite XUB2490HS-B1 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 21.9 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation)
- Matte black
- 54 cm x 23 cm x 36.5 cm
- 5.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- VESA DPMS, TUV Bauart, VCCI Class B
- Display Type
- Energy Class
- Class A
- 32 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Slim bezel design
- Matte black
- 5.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort , DVI-D , HDMI , Audio line-in
Mechanical
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x audio cable
- 21.9 W
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
