Share your vision with the ProLite TE8603MIS-B1AG - a perfect solution for educational and corporate use. Its large infrared 20-point touchscreen features Note, web browser, file manager, cloud drives, WPS office and ScreenSharePro. It comes with dual touch pens, allowing users to annotate easily in 4K on files and on-screen content which can be saved directly on a USB device, internal memory or on a connected cloud drive. The display supports playback of presentations, high-resolution video and almost any other type of content.
The high-quality commercial IPS LCD screen with a 4K Ultra HD resolution, 350cd/m² and a contrast ratio of 1200:1 for vibrant, detailed and high-quality images from anywhere in the class or meeting room. The anti-glare coating drastically reduces ambient reflection in high-brightness environments without compromising the sharpness and clarity of the image. The screen has a 24/7 non-stop operating time and is equipped with an all-metal bezel, 4 mm thick hardened glass to ensure long durability in high-use environments such as classrooms or meeting rooms.
Touch technology - infrared
This technology uses the infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
4K resolution
Ultra HD resolution, better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI, it displays an incredibly sharp and crisp image.
- iiyama ProLite TE8603MIS-B1AG 86" Class (85.6" viewable) LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with built-in media player and touchscreen (multi touch)
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- Yes - interactive
- Matte black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 32 GB
- Storage Capacity
- 32 GB
- USB
- 2 ports
- Included Accessories
- Remote control, 2 styluses, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- Power Consumption (On mode)
- 411 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 600 kWh
- Product Type
- Energy Class
- Class C
- 411 W
- 600 kWh
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- Yes - interactive
- Combined With
- Built-in media player and touchscreen (multi touch)
- Operating System
- Android OS
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- Modes
- Landscape mode, kiosk mode
- Cooling System
- Fanless
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 1200:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 20
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Dutch
- Infrared multitouch technology, Expansion Slot, designed for 24/7 operation, tempered glass (4mm)
Stands & Mounts
- Flat Panel Mount Interface
- 800 x 600 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 2
- Configuration
- ARM Cortex-A73 Dual-Core + ARM Cortex-A53 Dual-Core - 4 GB - 32 GB - Mali-G51
- 32 GB
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, cloud storage playback
- Connectivity
- Wi-Fi, LAN
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
- Connect & Share
- Screen Share
- Connector Type
- VGA input , 3 x HDMI , DisplayPort input , Audio input , RS-232 , LAN , HDMI output , SPDIF output , Audio output , USB 2.0 - bottom , USB 3.0 - top , 2 x USB 3.0 - side
- 2 styluses, batteries
- Cables Included
- HDMI cable , USB cable
- Plug and Play, DDC-2B, CB, WEEE, REACH, TUV Bauart, ERP, EAC
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
