The ProLite B2481HS is a high specification 24'' Full HD 1920 x 1080p LED-backlit monitor with super slim bezel. It features 2 ms response time and Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple input support of analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. A reliable solution for all kind of work environments where ergonomics and best performance are desired.
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product. -
ACR (Advanced Contrast Ratio)
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
HDMI
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
VESA
VESA mount compliance means you can easily mount your monitor to a wall. -
HAS (Height Adjustable Stand)
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
Overdrive on / off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Pivot
Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
- iiyama ProLite B2481HS-1 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 23.8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.35 cm x 40.5 cm x 24.45 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +85 / -85
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- sRGB colour management, HDCP, Eco-Mode
- Black
- 54.35 cm x 40.5 cm x 24.45 cm - with stand
- 5.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D , VGA , HDMI , Audio line-in
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 23.8 W
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- 0.5 Watt
- Included Software
- Driver
Sustainability Information
- ENERGY STAR Certified
