The ProLite E2773HS LED-backlit 27" monitor features a stunning 1 ms response time and a Full HD (1920 x1080) resolution. The high brightness and contrast offer the user clear and vivid images, and the HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and workstations. The X-Res technology feature helps to deliver best quality pictures even if the source is not perfect, like movies made with mobile device.
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen. -
X Res technology
The X-Res technology feature enhances pictures quality making sure they always look vivid and natural. Especially handy when enlarging lower definition pictures with rough edges, the feature helps to deliver better quality pictures giving the viewer a sense of higher resolution. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
HDMI
HDMI stands for high-definition multimedia interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product. -
Overdrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the overdrive feature will eliminate that. -
VESA
VESA mount compliance means you can easily mount your monitor to a wall. -
Speakers
This LED monitor is equipped with two high quality stereo speakers.
- iiyama ProLite E2773HS-1 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 45 kWh
- Power Consumption (On mode)
- 30.5 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1200:1 / 5000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.7 cm x 23.9 cm x 45.45 cm
- 5.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI Class B ITE, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart
- Display Type
- Energy Class
- Class A
- 45 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 76 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
- OSD Languages
- English, German, French, Polish, Russian, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology
- Black
- 5.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- 20
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, cable management clip
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 30.5 W
- Power Consumption (Typical)
- 29 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
Sustainability Information
- ENERGY STAR Certified
