Create a seamless 16:10 multi-display setup with the HP Z24n Narrow Bezel IPS Display, which has a virtually borderless screen for maximum impact imagery, factory color calibration to ensure optimal color accuracy, and flexible connectivity for all of your devices.
Virtually borderless viewing.
Enjoy a stunning visual experience with a 1920 x 1200 resolution and more than two million pixels. Maximize your view of the 61 cm (24") diagonal screen and seamlessly tile multiple displays with a design that only has a border on one side.
Ports aplenty for a perfect workspace.
Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. The DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
Out-of-the-box color.
Count on a factory-calibrated 99% sRGB color gamut from the very first time you power on for reliable, accurate color between displays and from project to project.
Enjoy a stunning visual experience with a 1920 x 1200 resolution and more than two million pixels. Maximize your view of the 61 cm (24") diagonal screen and seamlessly tile multiple displays with a design that only has a border on one side. -
Count on a factory-calibrated 99% sRGB color gamut from the very first time you power on for reliable, accurate color between displays and from project to project. -
- HP Z24n - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 24 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey), 8 ms (overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.38 cm x 21.01 cm x 52.02 cm
- 5.78 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL Grade 1, SEPA
- 5-year warranty
- Display Type
- Energy Class
- Class A
- 36 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 94.3
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 75 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Colour balance, input select, luminance
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, 99% sRGB colour gamut
- Black
- 53.38 cm x 21.01 cm x 52.02 cm - with stand
- 5.78 kg
- DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), HP Quick Release, detachable stand, VESA 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 24 W
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 53.38 cm - depth: 21.01 cm - height: 52.02 cm - weight: 5.78 kg , Without stand - width: 53.38 cm - depth: 4.93 cm - height: 35.11 cm - weight: 3.87 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
