Too smart to be called zero, the HP t5335z Smart Client is a uniquely intelligent zero client that adapts to your environment. Deploy for Citrix XenDesktop with support for HDX, or choose VMware View or Microsoft Session Virtualization via rDesktop.
Zero configuration
HP Smart Clients include an installation wizard for quick host server configuration. Intelligence is then automatically inherited from the data center, which drastically reduces solution implementation and deployment time.Simply connect the HP Smart Client to the network and a user monitor, keyboard and mouse - and you're on. The user is up and running quickly with no local user interface and just three steps from log-on to productivity. -
Zero management
At each boot up, the HP t5335z Smart Client automatically identifies the assigned environment from the server in seconds – even if the client virtualization software has been transitioned to a new environment.The HP Smart Client receives seamless updates as needed without individual IT support or interrupting the user session.Users have the flexibility to use the Profile Editor to make connection or preference changes in just a few clicks. Fall-back Intelligence on the client allows users to stay connected even if the server is offline. -
Zero compromise
HP Auto-sensing technology automatically connects to the network and searches for the right Citrix, VMware or Microsoft client virtualization infrastructure and downloads everything it needs to deliver a robust user experience.Deploy HP Smart Clients with the peace of mind that if your client virtualization software changes your HP Smart Clients will adapt to your environment. Simply repurpose your HP Smart Client for another protocol, saving time and money.Powerful ARM processor technology produces low heat emissions and delivers a rich, 1080p multimedia computing experience in Citrix XenDesktop environments.The solid-state design of the HP t5335z is near silent and fits in your environment - even attached to the back of a monitor with the HP QuickRelease - leaving no footprint for maximum workspace efficiency.HP Thin Clients are built to last with a computing platform designed for a complete lifecycle. And, these consistently reliable products are engineered and designed with quality in mind with a support community to back it up.
- HPE Smart Client t5335z - SFF - ARMADA 510 1.2 GHz - 1 GB - flash 512 MB
- Thin client - small form factor
- Processor
- 1 x Marvell ARMADA 510 / 1.2 GHz
- Cache Memory
- 512 KB
- Cache Per Processor
- 512 KB
- RAM
- 1 GB DDR3 SDRAM
- Hard Drive
- Flash 512 MB
- Optical Storage
- No optical drive
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 16 cm x 12 cm x 3.2 cm
- 480 g
- Environmental Standards
- ENERGY STAR Qualified
- Thin client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
Processor / Chipset
- CPU
- Marvell ARMADA 510
- Clock Speed
- 1.2 GHz
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 512 KB
- 512 KB
RAM
- Installed Size
- 1 GB
- Technology
- DDR3 SDRAM
Hard Drive
- Flash
- Capacity
- 512 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA, DVI
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 96 kHz
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Integrated
- Data Link Protocol
- DHCP support
- 1 x DVI-I , 1 x VGA (with adapter) , 4 x USB 2.0 (2 front, 2 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- FCC Class B certified, VCCI, GS, CB, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, WEEE
- Power adapter
- Voltage Required
- Power Provided
- 36 Watt
Operating System / Software
- OS Certified
- Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2000 Terminal Server, Microsoft Windows Server 2008, Citrix Presentation Server 4.5, Citrix Presentation Server 4.0
- ENERGY STAR Certified
- 16 cm
- 12 cm
- 3.2 cm
- 480 g
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
