HP t310 23.6" AIO Zero Client Teradici 2321 512MB 256MB
Quicklinx: BD0NWS00 Mfr#: J2N80AT#ABU
Maximize available workspace while saving time and money with the PCoIP-optimized HP t310 AiO Thin Client that connects users to your VMware networks in no time.
  • The perfect fit
    Get a fanless design and quiet thermals that support mass installments in small spaces plus a 23-inch diagonal screen that puts all your work front and center.
  • The whole package
    Be ready to go out of the box with an included keyboard and mouse.
  • Make it yours
    Customize your all-in-one with an array of inputs that support external peripherals, a second display, Ethernet, and audiovisual interactivity.
  • Technology designed for VMware
    Accelerate your hardware performance with Tera 2 PCoIP and the Teradici Tera 2321 processor.
  • Virtually risk-free
    Help protect your data and software by leaving it on the server, and your device with an optional HP Cable Lock.
  • One world
    Deploy the same configuration around the world with a Global Series SKU that ensures the same product everywhere you do business.
HP t310 - all-in-one Tera2321 - 512 MB - flash 256 MB - LED 23.6"
Zero client - all-in-one - PC over IP (PCoIP) technology
1 x Teradici Tera2321
RAM
512 MB DDR3 SDRAM
Hard Drive
Flash 256 MB
Optical Storage
No optical drive
Monitor
23.6" - LED - 1920 x 1080 (Full HD)
Audio Output
Stereo - integrated
GigE
55.68 cm x 16.38 cm x 39.95 cm
3.99 kg
Limited warranty - parts and labour - 3 years
Zero client
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Processor / Chipset
CPU
Teradici Tera2321
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
512 MB
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Hard Drive
Flash
256 MB
Optical Storage
No optical drive
Monitor
Monitor Type
LED
Diagonal Size
23.6"
Native Resolution
Widescreen Display
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Pixel Pitch
0.2715 mm
Response Time
5 ms
Image Brightness
300 cd/m²
Graphics Controller
Integrated
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
96 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Integrated
Wake on LAN (WoL), DHCP support
6 x USB 2.0 , 1 x microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-I
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
VCCI, EN 61000-3-2, ICES-003, ZH1 618, EN 61000-3-3, EN55024, UL 60950-1, IEC 60950-1, EN 60950-1, AES-128, AES-256
Power adapter
Power Provided
65 Watt
55.68 cm
16.38 cm
39.95 cm
3.99 kg
10 °C
10 - 90% (non-condensing)
