Sprout Pro by HP has plenty of power to handle everything from the office to the studio. It comes equipped with Windows 10 Pro, enhanced collaboration and sharing software that works with the dual screen experience, 20-point Touch Mat, dual video feeds and integrated 2D and 3D scanning.
HP Sprout, designed by HP, powered by Windows 10 and a 6th generation Intel ® Core™ i7 processor, is the all-in-one computer built to encourage collaboration, communication, and creativity.
HP Illuminator is at the heart of the Sprout, allowing users to scan 2D or 3D objects and instantly display them on the TouchMat with Intel® RealSense™ technology.
The Sprout is where the line between the physical and digital world has been blurred, bringing people's creativity to life in an instant; now anyone can grab something from the real world, manipulate it in the digital world, and bring it to life in physical space.
Users of any age can enjoy the Sprout's many impressive capabilities, including 2D/3D scanning, front and downwards facing cameras, an easy-to-use TouchMat, and a projector.
Incorporate the HP Sprout in the classroom for an innovative learning experience for students and teachers, or use the HP Sprout's 1TB of storage to store important content.
The HP Sprout is perfect for organisations willing to push the boundaries with industry-leading technology that helps bring people together.
The easiest way to create and learn
Sprout Pro by HP's breakthrough technology blends the physical and digital worlds. The HP Illuminator includes a 14 Megapixel High-Res camera, an Intel® RealSense™ 3D camera and a built-in projector displaying on a 20-point Touch Mat. When combined with simple yet powerful editing tools, Sprout Pro lets you quickly and easily bring your ideas to life.
Groundbreaking user interface
Sprout Pro by HP gives you a unique hands-on way to control and create with the power of touch. The two touch surfaces work together to transform your desk's surface into a digital-physical workspace. It's designed for a more intuitive, natural way to work without having to use a keyboard or mouse.
High performance All-in-One
At its core, Sprout Pro by HP is a high-performance All-In-One computer with an upgraded 6th generation Intel® Core™ i7 Processor3, 1TB of storage2, and new Windows 10 Pro1 operating system. So it has plenty of power for everything from the office to the studio.
Effortless collaboration
The Sprout Companion for Skype™ for Business4 enhances the experience of Skype™ on Sprout Pro by HP. Select between the Sprout camera inputs to show a video feed of your face or a physical object held over the mat. Perform a Sprout 2D capture during a Skype™ meeting which participants can view as an attachment. Move the Skype Meeting window between the vertical and horizontal displays with a single click which is great for marking on the Skype™ whiteboard using the stylus on the Touch Mat.
Featuring
Enhanced productivity and security
Windows 10 Pro1 is designed to provide a safer, innovative and updated experience while helping you to manage your devices, apps, and identities on your organization's network.
Enhanced scan software
HP Scan for Sprout software offers an enhanced experience for scanning documents.
Capture 3D scans
Grab any physical object, scan it, and start creating with a 3D digital replica on your screen.
Unique operating environment
Workspace is Sprout Pro's incredible operating environment. It was designed to simply and elegantly integrate Sprout Pro's unique capabilities to make editing as simple as possible. And it runs alongside Windows1 so you can get everything done.
Add a boost to your productivity
8GB of DDR4 memory technology5,6 supports higher speeds and bandwidth while delivering significant power savings.
Create it: Go for it.
From gaming to design, the NVIDIA® GeForce® GT 945A GPU on Sprout Pro by HP can be selectively used by apps to provide a welcomed performance boost when graphically intense endeavors most need it.
The power of touch
Designed for your hands and meant to be touched, the 20-point capacitive surface of the HP TouchMat lets up to four hands work at once. Just 2mm thick with a silky-smooth matte texture it hardly feels like you're working on top of technology.
Reinvent instruction
The HP External Display Mixer applet allows the teacher to share what's on the Sprout dual screen, video from the webcam, or the downward facing camera - or all at the same time.
Windows 10 Pro 64
- Sprout Pro by HP - all-in-one - Core i7 6700 3.4 GHz - 8 GB - Hybrid Drive 1 TB - LED 23" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- Hybrid Drive 1 TB (8 GB cache) - SATA 6Gb/s - 5400 rpm
- Optical Storage
- No optical drive
- Card Reader
- 3 in 1
- Monitor
- 23" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- NVIDIA GeForce 945A / Intel HD Graphics 530
- Video Memory
- 1 GB GDDR5 SDRAM
- Camera
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- CyberLink PowerDirector, Skype, HP Recovery Manager, HP Support Assistant, HP ePrint, HP MyRoom, Foxit PhantomPDF, HP Touchpoint Manager, Sprout Workspace, HP Scan for Sprout
- White
- 60.45 cm x 59.43 cm x 57.65 cm
- 15.28 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- LED lamp, DLP projector
- Embedded Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0)
- White
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H170
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 2 x 4 GB
Hard Drive
- Hybrid Drive
- Capacity
- 1 x 1 TB (8 GB cache)
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- LED
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 23"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Monitor Features
- Full HD wide-viewing angle (WVA), Mercury free, arsenic-free glass
Graphics Controller
- Graphics Processor
- Video Memory
- 1 GB GDDR5 SDRAM
- Video Interfaces
- HDMI
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 14 Megapixel
- 3D scanning
Input Device
- Mouse, keyboard, stylus, HP Illuminator, HP Touch Mat
Keyboard
- Connectivity
- Wireless
- Localization & Layout
- UK
- Audio control
Mouse
- Connectivity
- Wireless
- Technology
- Optical
Audio Input
- Stereo microphone
- Ethernet Controller
- Intel I219-V
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Wake on LAN (WoL), Intel Wireless Display (WiDi)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Bays
- 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x PCIe x1 Mini Card , 1 (total) / 0 (free) x CPU
- 2 x USB 2.0 (2 rear) , 2 x USB 3.0 (one of them is charging data port) , 1 x audio line-out (1 rear) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) (1 rear) , 1 x HDMI output (1 rear)
- Power supply
- Voltage Required
- Power Provided
- 350 Watt
- Efficiency
- 85%
- Power Factor Correction
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 60.45 cm
- 59.43 cm
- 57.65 cm
- 15.28 kg
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
