Keep up the good work with solid performance, a stylish large screen design, and environmental features all at an attractive price point with the HP ProDisplay P221 54,6 cm (21.5') LED Backlit Monitor. Efficiently grow and maintain your business with proven HP quality and reliability, stable lifecycles, HP accessory compatibility, and energy savings. Do more throughout the day and help save more throughout the quarter with a monitor that goes the distance.
Essential business features
Support your business needs at a competitive price with a large 54,6 cm (21.5') diagonal LED display. Review documents side by side, read e-mails while multitasking in another window, and keep more applications open at the same time.See the difference with an LED display for vibrant text and graphics presentation. LED technology also makes your display thin, light, and easy to position on the desk.Deliver clear views for single and multiple users with wide viewing angles. High contrast ratios and fast response times keep your content crisp and readable throughout the day.Work comfortably with up to 30 degrees of tilt on the adjustable design, and easily connect to devices with the convenient VGA and DVI inputs. The internal power supply minimizes clutter on the desktop and simplifies setup and deployment. -
Compatibility with HP accessories
Customize your work space with options like the HP Quick Release, HP Speaker Bar and HP USB Graphics Adapter (options sold separately).Free up valuable space and lift the monitor completely off the desk. The 100-mm standard VESA pattern allows mounting on a HP Monitor Arm, HP Stand, the HP Quick Release and other VESA-compatible accessories (options sold separately). -
Stability now, and peace of mind for the future
Maintain product consistency across staggered deployments, ease transitions and help reduce support costs with a minimum one-year lifecycle stability commitment from HP.Support identical installations and unify your operations worldwide with globally consistent products in over 145 countries.Get improved reliability and peace of mind from HP quality standard testing that puts our monitors through their paces before you do.Rest assured that your IT investment is supported by a standard, three-year limited warranty. Select HP Care Pack Services to extend service contracts beyond the standard warranties. -
Smart software for the multi-tasker
HP Display Assistant consolidates monitor setting controls into one easy-to-use, centralized interface.Customize your workspace with resizable screen partitions that let you work on a document in one partition, refer to a spreadsheet in another, and check e-mails in another-at the same time.Use the new expanded toolbar to view the applications you're using across all of your connected displays. -
Energy efficient, environmentally aware
Mercury-Free LED backlighting, a BFR/PVC-free design, and arsenic-free display glass are just a few of the environmental features built into this display.Help lower your overall bottom line with award-winning eco-certifications, including ENERGY STAR , EPEAT Gold and TCO.
- HP ProDisplay P221 - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.8 cm x 16 cm x 37.9 cm
- 4 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, VCCI, BSMI CNS 13438 Class B, CCIB, cUL, GS, EN55022 Class B, CCEE, FCC Part 15, EN55024 Class B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, CISPR, GEEA, AS/NZS 3548 Class B, MEPS, CSA C22.2 No. 60950-1, KC, CEL
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 9300K, 6500K
- Controls & Adjustments
- Brightness, contrast, colour temperature, phase, clock
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- Black
- 51.8 cm x 16 cm x 37.9 cm - with stand
- 4 kg
- DVI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 51.8 cm - depth: 16 cm - height: 37.9 cm - weight: 4 kg , Without stand - width: 51.8 cm - depth: 4.75 cm - height: 31.52 cm - weight: 3.3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
