Enjoy a stylish, height-adjustable display with sharp QHD resolution and ultra-wide viewing angles on the HP P24q 23.8" monitor. This ultra slim, 3-sided micro-edge display comes at a great value with convenient HDMI and VGA connectivity.
Find your sweet spot
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view. -
Divide and conquer
Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval. -
We have your back
We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
- HP P24q G4 - P-Series - LED monitor - 23.8" - Smart Buy
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class G
- Power Consumption (On mode)
- 26 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2058 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.06 cm x 21.16 cm x 46.33 cm
- 5.59 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Plug and Play, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, ICES, S Mark, cTUVus, TUV Bauart, China Energy Label Level 2, CEC, ERP, CECP, CEL, EAC, UAE, Ukraine Energy Label
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2058 mm
- Pixel Per Inch
- 123
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- High Frame Rate Control (Hi-FRC), Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth
- Black
- 54.06 cm x 21.16 cm x 46.33 cm - with stand
- 5.59 kg
- HDMI , VGA
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
- Cables Included
- 1 x HDMI cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 54.06 cm - depth: 21.16 cm - height: 46.33 cm - weight: 5.59 kg , Without stand - width: 54.06 cm - depth: 4.69 cm - height: 32.25 cm - weight: 3.42 kg
- Shipping Width
- 63.9 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 41.9 cm
- Shipping Weight
- 7.59 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.87 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.70 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.83 |
