HP Officejet Pro 8620 Multifunction Printer
Quicklinx: 9HDNWS00 Mfr#: A7F65A#A80
Print professional-quality colour for up to 50% lower cost per page than lasers with this high productivity business e-all-in-one. Print using the large touchscreen, wirelessly, on the go or via your NFC-enabled device.[2,3,4].
  • Print from the office or on the go via your smartphone, tablet or notebook
    Print with just a touch from your NFC-enabled smartphone or tablet.Print wirelessly from your mobile device - no router or access to local network needed.Enjoy easy printing from your smartphone, tablet and notebook when you're on the go, with HP ePrint.Share high-productivity print tools across the office with 10/100 Ethernet connectivity.
  • Get more done with a range of productivity-enhancing business tools
    Tap and swipe the large touchscreen to access time-saving apps and manage print, copy, scan and fax tasks.Boost productivity with fast two-sided printing, copying and scanning, and 50-page automatic document feeder.Scan to email, network folders, and the cloud - LDAP directory lookup locates your email destination.Handle high volume print jobs with confidence - up to 30,000-page monthly duty cycle.
HP Officejet Pro 8620 e-All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 14 ppm (mono) / up to 13 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 21 ppm (mono) / up to 16.5 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thin paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Scan to e-mail
AC 120/230 V (50/60Hz)
49.93 cm x 46.89 cm x 31.4 cm
12.98 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 1500 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Scan to e-mail
Standard Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Max Original Size
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
250 sheets
Max Media Capacity
500 sheets
150 sheets
ADF - 35 sheets , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 21 ppm (A4) - B/W (ISO) , Printing: up to 16.5 ppm (A4) - colour (ISO) , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft , Copying: up to 14 ppm (A4) - B/W (ISO) , Copying: up to 13 ppm (A4) - colour (ISO) , Copying: up to 34 ppm (Letter A) - B/W draft , Copying: up to 34 ppm (Letter A) - colour draft , Scanning: up to 6 ipm - B/W duplex , Scanning: up to 6 ipm - colour duplex
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, TLS
Operating System Support
Linux, MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8.1, Apple Mac OS X 10.9
Software Included
Drivers & Utilities
35 Watt
Power Consumption Standby
6.8 Watt
Power Consumption Sleep
2.2 Watt
Consumables Included
1 x ink cartridge (black) - up to 1000 pages - HP 950 , 1 x ink cartridge (cyan) - up to 700 pages - HP 951 , 1 x ink cartridge (magenta) - up to 700 pages - HP 951 , 1 x ink cartridge (yellow) - up to 700 pages - HP 951
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
Limited warranty - 3 years with product registration (within 60 days of purchase)
49.93 cm
46.89 cm
31.4 cm
12.98 kg
Shipping Width
56.9 cm
Shipping Depth
37.7 cm
Shipping Height
51.8 cm
Shipping Weight
16.24 kg
Sound Emission
64 dBA (operating)
5 °C
25 - 75%
