Count on fast print speeds up to to 22 ppm, automatic two-sided printing, reliable Wi-Fi connectivity, and a 250 sheet paper tray. Choose HP+ and get 6 months of Instant Ink and 1 extra year HP warranty with use of Original HP Ink.
This printer is best for shared home offices managing records and printing professional colour presentations.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits.
Customisable shortcuts on your phone or printer
Eliminate steps in repetitive tasks with Shortcuts in HP Smart app. -
Create editable, searchable documents
With Shortcuts in HP Smart app, you can create editable, searchable documents by scanning from your phone or printer. -
Two-sided. Hands-free. Auto-fed
Work fast and hands-free with the 35 page auto-feeder. Get automatic two-sided printing and scanning. -
Ready when you are
Connect to cloud-based printing with Wi-Fi or your cellular network. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
- HP Officejet Pro 9010e All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 15 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
- Power
- AC 120/230 V (50/60Hz)
- 43.93 cm x 38.22 cm x 27.8 cm
- 9.29 kg
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- 1500 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 6272 nozzles
- Ink Cartridge Configuration
- 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
- Ink Palette Supported (Colours)
- Pigment cyan, pigment magenta, pigment yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Min Original Size
- 76.2 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 110 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), A4 (210 x 297 mm)
- Borderless Photo Sizes
- 250 sheets
- 250 sheets
- 60 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
- Speed Details
- Printing: up to 22 ppm (A4) - B/W (ISO) , Printing: up to 18 ppm (A4) - colour (ISO) , Printing: up to 32 ppm (A4) - B/W draft , Printing: up to 32 ppm (A4) - colour draft , Copying: up to 32 ppm (A4) - B/W draft , Copying: up to 32 ppm (A4) - colour draft , Scanning: up to 8 ppm (A4) - B/W , Scanning: up to 8 ipm (A4) - colour , Scanning: up to 4 ppm (A4) - B/W duplex , Scanning: up to 4 ppm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 4 ppm (A4) - colour best
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- SSL, TLS, WPA2, 802.1x, WPA2-Enterprise
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
- Software Included
- Software HP Printer
- Voltage Required
- 30 Watt
- Power Consumption Standby
- 5.8 Watt
- Power Consumption Sleep
- 1.2 Watt
- First Copy Out Time B/W
- 7 sec
- First Copy Out Time Colour
- 9 sec
- Consumables Included
- 1 x ink cartridge (black) - HP 963 , 1 x ink cartridge (cyan) - HP 963 , 1 x ink cartridge (magenta) - HP 963 , 1 x ink cartridge (yellow) - HP 963
- BSMI, GS, IC CS-03, CCC, ANATEL, FCC CFR47 Part 15 B, EAC, ICASA, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TIA-1096, EN 301 489-1, EN 61000-3-2:2014, CNC, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, TIA-968-B, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, SCT, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Limited warranty - parts - 1 year , Technical support - web support - 1 year
- 43.93 cm
- 38.22 cm
- 27.8 cm
- 9.29 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 32.5 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 11.02 kg
- Sound Emission
- 63 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
Ink (9)
HP 963 Black Original Ink Cartridge | In Stock | £23.08 |
HP 963 Cyan Original Ink Cartridge | In Stock | £16.18 |
HP 963 Magenta Original Ink Cartridge | In Stock | £16.53 |
HP 963 Yellow Original Ink Cartridge | In Stock | £16.18 |
HP 963XL High Yield Black Original Ink Cartridge | In Stock | £33.68 |
HP 963XL High Yield Cyan Original Ink Cartridge | In Stock | £25.70 |
HP 963XL High Yield Magenta Original Ink Cartridge | In Stock | £25.70 |
HP 963XL High Yield Yellow Original Ink Cartridge | In Stock | £25.70 |
HP HP 963 4-Pack Original Ink Cartridge | In Stock | £65.86 |
