This modern printer is built for maximum productivity with fast speeds and reliable hardware, delivering effortless everyday use so you can focus more on your business. And with HP+, printers have never been easier to manage and use from anywhere.
This is an HP+ printer. It requires an HP account, connection to the internet, and exclusive use of Original HP Toner cartridges for the life of the printer. More at:
Large workteam solution
Support your dynamic workteam with this high-speed, multi-feature printer, ideal for up to 10 users. -
Blazing fast speed
Step up your workflow with blazing fast speed to meet high-demand environments. -
Simple shortcuts
Do more in fewer steps. Simple shortcuts allow your employees to complete common tasks with just a touch. -
Set up. Invite users. And done
Guided, cloud-based setup makes it easy to configure new printers and onboard users from any location. -
Control at your fingertips
Smart Admin Dashboard monitors usage and control settings across multiple printers, in multiple locations. -
HP Smart
Get productivity in the palm of your hand. Print and save time with Shortcuts from HP Smart.
- HP LaserJet Pro 4002dwe - printer - B/W - laser - with HP+
- Printer Type
- Workgroup printer - laser - B/W
- Number of Users
- Up to 10 users
- 8.22 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 42 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 63 ppm - black landscape - A5 (148 x 210 mm) , Up to 14 ppm - black portrait - A5 (148 x 210 mm) , Up to 36 ipm - duplex - ANSI A (Letter) (216 x 279 mm) , Up to 34 ipm - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 4800 x 600 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Bluetooth, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF, URF, PWG
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, light-weight paper, preprinted paper, letterheaded paper, coloured paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Printer Features
- Print from mobile device, Instant-on Technology, Mopria certified, Auto Power On, Auto Power Off, JetIntelligence Cartridge Technology, HP Instant Ink
- Power
- AC 220-240 V
- System Requirements
- UNIX, Microsoft Windows Server, Microsoft Windows 7, Android, Apple iOS, Windows 10, Apple macOS 10.15, Citrix, Apple macOS 11.0, Apple macOS 12, Windows 11
- 2-year warranty
- 38.1 cm x 35.7 cm x 21.6 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Number of Users
- Up to 10 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- 2 line monochrome LCD display
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 4800 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.3 sec
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 197 x 273 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- Media Weight (lbs)
- 16 lbs - 53 lbs
- 350 sheets
- Media Feeders
- Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 46.6 lbs (max)) , Input tray: 1 - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max)) , Output tray: 1 - 150 sheets
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, IPP, HTTP, HTTPS, SLP, DHCP, IPv4, IPv6
- SSL, Apple Bonjour, IPv6 support
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2900 pages
- EN 61000-4-12, EN 62479:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, FCC CFR47 Part 15 B Class B, CISPR 32 Class B, EN 62368-1:2014, EN 60825-1:2014, EN 55032:2012 Class B, IEC 60825-1:2014, IEEE 802.3az, Mercury-free, IEC 62368-1: 2014, IPv6, EN 61000-3-2:2019, CISPR 35: 2016, EN 61000-3-3:2013+A1:2019, IEC 61000-3-2:2019, ICES-003 issue 7, EN 55035 Class B, IPv4
- Power Device
- Power supply - internal
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 495 Watt
- Power Consumption Stand by
- 5.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- System Requirements Details
- HD 2 GB
Environmental Standards
- Blue Angel
- ENERGY STAR
- ENERGY STAR Version
- 3.0
- Limited warranty - 2 years
- 10 °C
- 32.5 °C
- 10 - 80% RH
- Sound Emission (Operating)
- 54 dBA
- 38.1 cm
- 35.7 cm
- 21.6 cm
- 8.22 kg
- Width (Shipping)
- 44.3 cm
- Depth (Shipping)
- 27.4 cm
- Height (Shipping)
- 46.4 cm
- Weight (Shipping)
- 10.5 kg
Ink (1)
HP HP - Black - original - LaserJet - toner cartridge | In Stock | £82.48 |
Other bundles (1)
HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn | In Stock | £98.06 |
