This HP LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
- HP LaserJet Enterprise M612dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 21.6 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 75 ppm - ANSI A (Letter) (216 x 279 mm) , Up to 71 ppm - A4 (210 x 297 mm) , Up to 62 inch/min - duplex - ANSI A (Letter) (216 x 279 mm) , Up to 58 inch/min - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (1.5 GB)
- Hard Drive
- 4 GB
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, recycled paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper, letterheaded paper, coloured paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 550-sheet input tray, 100-sheet input tray
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 30000 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, Auto Power On, Auto Power Off, watermarks
- System Requirements
- UNIX, Novell NetWare 6.5, Microsoft Windows Server 2003 R2 SP2, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Citrix Presentation Server 4.5, Citrix MetaFrame XP Presentation Server, Citrix MetaFrame Presentation Server 3.0, Citrix Presentation Server 4.0, Android, Red Hat Enterprise Linux 6, Microsoft Windows Server 2008 R2 SP1, Microsoft Windows Server 2008 (32/64-bits) SP1, Microsoft Windows Server 2008 (32/64-bits) SP2, Microsoft Windows Server 2003 R2 SP1, Citrix XenApp 5, Citrix XenApp 6, Ubuntu 12.04, Microsoft Windows Server 2012, Microsoft Windows Server 2008 R2 SP1 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Citrix XenApp 6.5, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04, Novell Open Enterprise Server 11, Red Hat Enterprise Linux 7, Ubuntu 15.10, Debian Linux 7.4, Apple MacOS X 10.10, Debian Linux 7.0, Citrix XenDesktop 5.6, Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.1 or later, Apple MacOS X 10.11, Debian GNU/Linux 8.0, Microsoft Windows Server 2003 (32-bits), Citrix XenApp 7.5, Citrix XenDesktop 7, Linux Mint 17.1, Microsoft Windows XP / Vista / 7 / 8.1 / 10 (32/64 bits), Ubuntu 16.04, Linux Mint 17.2, Linux Mint 17.3, SUSE Linux 13.2, Microsoft Windows Server 2016 (64-bit), Apple macOS 10.12, Linux Mint 18, Citrix XenDesktop 7.5, SUSE Linux 42.1, Linux Fedora 23, Linux Fedora 24, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Debian Linux 7.2, Debian Linux 7.3, Debian Linux 7.5, Debian Linux 7.6, Debian Linux 7.7, Debian Linux 7.8, Debian Linux 7.9, Ubuntu 16.10, Microsoft Windows Server 2008 R2 (32/64-bits) SP2
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 43.1 cm x 46.6 cm x 38 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- 4.3 inch LCD touch screen
- 4.3"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- HP FastRes 1200
- PostScript Support
- Standard
- First Print Out Time B/W
- 5.1 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 1.5 GB (max)
- Slots Qty
- 1
Storage
- Hard Drive
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 76.2 x 127 mm, 127 x 177.8 mm, 99 x 148 mm, 216 x 340 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 216 x 356 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), A5 (148 x 210 mm)/Half Letter (140 x 216 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- Media Weight (lbs)
- 16 lbs - 53 lbs
- 650 sheets
- Media Feeders
- Input tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 53 lbs (max)) , Input tray: 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max)) , Output tray: 1 - 500 sheets
- Max Media Capacity
- 4400 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 300000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, IPP 2.0, SLP, DHCP
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES-128, ARP, AES-256, EAP-TLS, PEAP, Secure Erase, IPv6 support
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 10500 pages
- Security lock slot (cable lock sold separately), Secure Erase
- UL, CISPR 22 Class A, cUL, GS, CECP, Directive 2006/95/EC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 62479:2010, EMC 2004/108/EC, 21 CFR 1040.10, 21 CFR 1040.11, CoC, EN 55024:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, FCC CFR47 Part 15 A, FIPS 140, IEEE 802.3az, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- Electric Current Required
- 12 A
- 780 Watt
- Power Consumption Stand by
- 15.3 Watt
- Power Consumption Sleep
- 3.1 Watt
- Software Included
- Drivers & Utilities, HP Device Experience (DXP), HP Connected
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 32.5 °C
- 30 - 70%
- Sound Emission (Operating)
- 55 dBA
- 43.1 cm
- 46.6 cm
- 38 cm
- 21.6 kg
Ink (2)
HP L0H25A Service-Kit, 225K pages | In Stock | £292.39 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
Other bundles (1)
HP Media Tray / Feeder 550 sheets For LaserJet | In Stock | £220.69 |
