Impressive performance that fits right in. The design looks amazing. Your business performance will look even better. Trust your mission-critical projects to an all-in-one PC that's built to handle the demands of virtually any business environment. Power your workday with a secure, enterprise-class PC that's easy to manage and just as reliable as it is stylish. Integrate optional touch computing in select models for a truly hands-on experience.
Stylish efficiency from edge to edge
Turn the front room into the showroom, and optimize the space of your back room as well. With slim, sleek glass across a 23-inch diagonal screen, this all-in-one PC impresses virtually anywhere.Stay organized and free up more room for work. This space-saving all-in-one has several stand options, and easily mounts on the wall. -
Fast-track your performance
Quickly open new files and switch applications with less wait time thanks to solid-state drives and solid-state hybrid drive options. Get the latest processing technology with a choice of 4th generation Intel Core processors.Watch your inbox while working on other tasks. Connect up to four displays, using the digital DisplayPort with multi-stream and optional discrete graphics card.Intel Smart Response Technology (SRT), a disk cache solution, delivers similar performance associated with Solid State Drives while retaining the data storage capacity of today's large Hard Disk Drives.Make the most of virtual conferencing. Bring work to life through rich sound and video using DTS Studio Sound and an HD webcam. -
Experience the simplicity of touch in select models
Delight users with the intuitive control of an optional 10-point capacitive touchscreen that makes the most of Windows 8. Rotation sensors let you see what's on screen as it was meant to be displayed by rotating from landscape to portrait. -
The hub of your mobile world
Speed up charging with a fast charging USB port. The nearly 2.8x stronger charging current helps compatible devices charge faster than standard USB 3.0 ports.Easily share your internet connection with your devices and help colleagues get online fast with HP Wireless Hotspot.Maintain tighter control over device security. Use the optional integrated near-field communications (NFC) capabilities to support custom applications such as advanced user authentication. -
Heavy security, efficiently managed, reliability for the long haul
Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of HP Client Security and Intel vPro management features.Save your data. RAID configurations utilize dual storage drives to automatically back up and help protect your sensitive data.Count on the support you need to get long-term value out of your investment. This work-ready PC is designed for a long lifecycle, with platform stability up to 30 months.Rest assured. Talk to an agent any time and get priority service at any HP repair center with HP Elite Premium Support, at no additional charge.HP EliteOne PCs are rigorously tested to help ensure reliability. During the HP Total Test Process, our PCs experience 115,000 hours of performance trials to help get you through your business day.
- HP EliteOne 800 G1 - all-in-one - Core i5 4570S 2.9 GHz - vPro - 4 GB - HDD 500 GB - LED 23" - TAA Compliant
- Personal computer - all-in-one - administrator password, power-on password, chassis intrusion detection, wall mountable, HP File Sanitizer, HP BIOS Protection
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (4th Gen) 4570S / 2.9 GHz (3.6 GHz) (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 4 in 1
- Monitor
- 23" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics 4600 Dynamic Video Memory Technology
- Audio Output
- Stereo - integrated
- Networking
- GigE, 802.11a, 802.11b/g/n
- Power
- AC 120/230 V
- OS Provided
- Windows 8 Pro 64-bit Edition
- Software Included
- Cyberlink PowerDVD, CyberLink PowerDirector, CyberLink Power2Go, Skype, PDF Complete, HP Recovery Manager, HP Support Assistant, EverNote, HP ePrint, CyberLink Media Suite, Windows Defender, CyberLink PhotoDirector, Device Access Manager, HP Wireless Hotspot (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, HP Disk Sanitiser (free download)
- 56 cm x 19.48 cm x 52.89 cm
- 14.32 kg
- Pricing Type
- Promo
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- All-in-one - with adjustable stand
- Built-in Devices
- Capacitive touch screen
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 4 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 23"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 179
- Vertical Viewing Angle
- 179
- Colour Gamut
- 72%
- Pixel Pitch
- 0.256 mm
- Image Contrast Ratio
- 1000:1
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
- Speakers Included
- 2 x right / left channel
Input Device
- Mouse, keyboard, touch-screen
Keyboard
- Connectivity
- Wireless
Mouse
- Connectivity
- Wireless
- Ethernet Controller
- Intel I217-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Centrino Advanced-N 6205
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X), Intel Wireless Display (WiDi)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x MXM 3.0 Type A , 1 (total) / 0 (free) x PCIe Half Mini Card , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x mSATA
- 6 x USB 3.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x microphone , 1 x headphones , 1 x serial , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
- Administrator password, power-on password, chassis intrusion detection, wall mountable, HP File Sanitizer, HP BIOS Protection
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- CSA, UL, CCC, FCC, Energy-using Products (EuP) Lot 6, CECP
- Pricing Type
- Promo
- TAA Compliant
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 200 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 93%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 56 cm
- 19.48 cm
- 52.89 cm
- 14.32 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
