IPS goes mainstream with the HP EliteDisplay E241i 61 cm (24') IPS LED Backlit Monitor, a business-class combination of a large screen, extra-wide viewing angles, and extraordinary comfort.
Enhance your view and get connected
Crisp, clear content on this 24-inch diagonal, 16:10 aspect ratio screen from the high 5M: 1 dynamic contrast ratio. Connect with VGA, DVI, and DisplayPort inputs and integrated two-port USB hub. -
See more, do more, and be more comfortable
Create a whole world view with a monitor for every task. With multiple monitors, you can design a workspace that puts everything you need front and center on the desk. -
Your monitor's new best friend
Personalize your screen with HP Display Assistant software and view open applications on your connected displays. Deter theft with a user-designated PIN that deactivates the monitor if disconnected. -
Global reassurance
Rest assured your IT investment is supported by a three-year standard limited warranty. To extend your protection beyond the standard warranties, select optional HP Care Pack Services.
- HP EliteDisplay E241i - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Meteorite
- Dimensions (WxDxH) - without stand
- 55.6 cm x 5.5 cm x 36.26 cm
- 4.11 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV GS, VCCI, C-Tick, NOM, TUV Ergo, PSB, E-Standby
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 31 - 80 KHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- Controls & Adjustments
- Brightness, contrast, colour temperature
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- Meteorite
- 55.6 cm x 5.5 cm x 36.26 cm - without stand
- 4.11 kg
- USB 2.0 upstream , 2 x USB 2.0 downstream , DVI-D (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Security lock slot (cable lock sold separately), Low-Smoke Zero Halogen (LSZH)
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable , 1 x USB cable
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 55.6 cm - depth: 5.5 cm - height: 36.26 cm - weight: 4.11 kg , With stand - width: 55.6 cm - depth: 27.62 cm - height: 51.65 cm - weight: 6.58 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 25 - 85% (non-condensing)
