Give your business-critical users the display they crave. The HP EliteDisplay E231 58,4 cm (23') LED Backlit Monitor delivers outstanding ergonomic adjustability and convenient connectivity in a premier, energy efficient design.
Enhance your view, advance your connectivity
Bring your content to life with Full-HD resolution. Get vibrant text and graphics from the LED backlit panel, which also makes the monitor thin, light, and easy to position on a desk.Deliver clear views with wide viewing angles, and keep your content crisp and readable with high contrast ratios and fast response times.Easily connect devices with convenient VGA, DVI, and DisplayPort inputs and an integrated USB hub.Work on a document in one partition, refer to a spreadsheet in another, and check e-mails in another-at the same time with HP Display Assistant. Customize your workspace with resizable screen partitions through an easy-to-use, centralized interface.Use HP Display Assistant's new expanded toolbar to view open applications on all of your connected displays. Deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval. -
Get comfortable with HP's ultimate adjustable design
Find your most comfortable working position so you can power through your day. Customizable tilt, height adjustment, swivel, and pivot settings-the most adjustability available on an HP business display-help you find your sweet spot. -
Control your environmental impact
Reduce power consumption and help lower your costs with an intelligent, energy efficient design that carries ENERGY STAR , EPEAT Gold , and TCO certifications.Help decrease your eco-footprint with Mercury-free LED display backlighting, a low-halogen design and arsenic-free display glass. -
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty. Select optional HP Care Pack Services to extend your protection beyond the standard warranties.Get award-winning service and support by phone or online.
- HP EliteDisplay E231 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - without stand
- 54.4 cm x 5.1 cm x 32.9 cm
- 6.1 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- VCCI, NOM, TUV S, ISO 14001, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, KC, CECP, CEL, EPA
- 3-year warranty
- Display Type
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Video Bandwidth
- 200 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- Controls & Adjustments
- Brightness, contrast, colour temperature
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, detachable, Frame Rate Control (FRC), On-screen Digital Controls, PIN code protection
- Black
- 54.4 cm x 5.1 cm x 32.9 cm - without stand
- 6.1 kg
- USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , DVI-D (HDCP) , DisplayPort (HDCP) , VGA (HD-15)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 36 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 54.4 cm - depth: 5.1 cm - height: 32.9 cm - weight: 6.1 kg , With stand - width: 54.4 cm - depth: 24.24 cm - height: 46.99 cm
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
