Speed and colour are the perfect pair for your business. That's why this energy-efficient printer and Original HP Toner cartridges with JetIntelligence combine to produce vibrant, professional-quality documents right when employees need them.
Enjoy high-speed performance, right when you need it
Print from sleep mode in as fast as 9 seconds. Get two-sided prints as quickly as one – up to 40 ipm.This printer uses exceptionally low amounts of energy – thanks to smart media-sensing and toner technology.Equip employees to fly through tasks with the adjustable 10.9 cm (4.3-inch) colour touchscreen.Consistently print high-quality documents across a variety of media – including A5 – with automatic media sensing. -
Keep your printer fleet simple, protected and streamlined
Centralise control of your print environment with HP Web Jetadmin – and help build business efficiency.Protect sensitive data with embedded or optional features, including HP JetAdvantage Security Solutions.Easily develop, deploy and add on HP and third-party solutions. Choose the optional 1 GB memory upgrade.Increase security, restore control and help avoid additional expenses with HP JetAdvantage Private Print. -
Print whenever business demands
Enable wireless direct printing in the office – from mobile devices – without accessing the network.Print with just a touch of your NFC-enabled mobile device to this printer – no network needed.Easily print from a variety of smartphones and tablets – generally no setup or apps required. -
Get more pages, performance and protection
Original HP Toner cartridges with JetIntelligence deliver more pages per cartridge than predecessors.Count on professional quality at fast speeds – HP ColorSphere 3 toner works best with your HP printer.Help ensure the authentic HP quality you paid for with anti-fraud and cartridge authentication technology.Print right away with preinstalled cartridges. Replace them with optional high-yield cartridges.
- HP Color LaserJet Enterprise M553x - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 33.4 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 40 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 38 ppm - colour - A4 (210 x 297 mm) , Up to 40 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 38 ipm - colour duplex - A4 (210 x 297 mm) , Up to 40 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 59 ppm - B/W - A5 (148 x 210 mm) , Up to 59 ppm - colour - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, NFC, USB 2.0 host
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 1 GB (2 GB) - DDR3 SDRAM - DIMM 90-pin
- Flash Memory Installed (Max)
- 4 GB
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
- Total Media Capacity
- 1200 sheets
- Media Handling
- 100-sheet multipurpose tray, 2x 550-sheet input trays
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 6000 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, Instant-on Technology
- System Requirements
- UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
- 1-year warranty
- 45.8 cm x 47.9 cm x 58.1 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- 4.3 inch LCD touch screen
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 1 GB / 2 GB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Flash Memory
- Flash Memory
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 1200 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - 216 x 297 mm weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 2300 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 80000 pages
- 2000 - 6000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
- Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 5000 pages ISO/IEC 19798
- FCC Class A certified, CISPR 22 Class A, Laser Class 1, FCC CFR47 Part 15, IEC 60825-1, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, EN 62479:2010, IEC 60950-1:2005, EN 55024:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 624 Watt
- Power Consumption Stand by
- 33.6 Watt
- Power Consumption Sleep
- 3.95 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 15 °C
- 30 °C
- 10 - 80%
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 51 dBA
- 45.8 cm
- 47.9 cm
- 58.1 cm
- 33.4 kg
- Width (Shipping)
- 75 cm
- Depth (Shipping)
- 60 cm
- Height (Shipping)
- 59.8 cm
- Weight (Shipping)
- 38.6 kg
Ink (11)
HP 508A Black Original Toner Cartridge | In Stock | £135.46 |
HP 508A Cyan Original Toner Cartridge | In Stock | £169.83 |
HP 508A Yellow Original Toner Cartridge | In Stock | £170.57 |
HP 508A Magenta Original Toner Cartridge | In Stock | £169.83 |
HP 508X High Yield Black Original Toner Cartridge | In Stock | £189.38 |
HP 508X High Yield Cyan Original Toner Cartridge | In Stock | £262.17 |
HP 508X High Yield Yellow Original Toner Cartridge | In Stock | £262.17 |
HP 508X High Yield Magenta Original Toner Cartridge | In Stock | £262.17 |
HP M522 Laserjet Toner Collection Unit | In Stock | £17.93 |
HP M522 220V Fuser Unit | In Stock | £177.09 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.38 |
