HP Color LaserJet Enterprise CP4025n Colour Laser Printer
HP Color LaserJet Enterprise CP4025n Printer
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 6N9FWS00 Mfr#: CC489A#B19
Print professional-quality colour documents at high speeds. Efficient paper handling and intuitive controls keep workgroups productive. With energy-saving features, your business can save money while reducing your environmental impact.
  • Powerful performance
    Improve workgroup efficiency with print speeds up to 35 ppm A4 and a first page out in as fast as 9.5 seconds with Instant-on Technology.Handle a steady stream of print jobs and still stay productive.With 512 MB of memory, expandable up to 1 GB (1024 MB), this printer can store and process a large queue of documents.Easily integrate best-in-class networking and robust security options into your printing set-up.Expand the number of IP addresses on your network with IPv6.
  • Brilliant, professional-quality colour communications
    Achieve consistent, accurate colour with HP ImageREt 3600 and up to 1200 x 1200 dpi for smooth colour transitions, crisp text and sharp images.Save IT time and make printing easy for every user with the improved HP Universal Print Driver and HP EasyColor.Use Original HP supplies for outstanding, reliable results.Manage your colour printing costs using award-winning HP colour access controls, which enable you to assign colour access by user or by application, or turn off colour capability completely.
  • Easy and efficient operation
    Produce documents efficiently with automatic two-sided printing and a paper capacity of 600 sheets, expandable to 1,100 sheets.A 4-line colour display panel makes operation easy and straightforward.Simplify printing for multiple users and print jobs with HP Advanced Auto Media Sensing, which automatically adjusts settings according to paper type.With twenty-five years of continuous innovation and reliable, professional-quality printing, HP LaserJet remains the brand businesses count on.
  • Minimise your environmental impact
    Get up to 50 percent energy savings over competitive laser products, using Instant-on Technology.Reduce your impact on the environment and use up to 50 percent less paper with two-sided printing.Reduce packaging waste with pre-installed toner cartridges - no boxes, wrappers or manuals.Implement energy-saving settings across your entire fleet with HP Web Jetadmin.
HP Color LaserJet Enterprise CP4025n - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
38.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - Legal (216 x 356 mm) , Up to 35 ppm - colour - Legal (216 x 356 mm)
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
Image Enhancement Technology
HP ImageREt 3600
USB, Gigabit LAN
800 MHz
RAM Installed (Max)
512 MB (1 GB) - DDR2 SDRAM - SO-DIMM 200-pin
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.4
Media Type
Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper
Total Media Capacity
600 sheets
Monthly Duty Cycle (max)
100000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
Microsoft Windows 2000, Red Hat Linux 7.0 or later, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, SuSE Linux 8.x, Apple MacOS X 10.4, Apple MacOS X 10.3.9, Microsoft Windows Vista, Microsoft Windows 7 Professional, Microsoft Windows 7 Home Premium, Microsoft Windows 7 Ultimate, Microsoft Windows 7 64-bit Edition, Microsoft Windows 7 Enterprise, Microsoft Windows 7 Home Basic, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.5 or later, Microsoft Windows Server 2008
1-year warranty
54 cm x 52.2 cm x 42 cm
Printer Type
Printer
Print Speed
Wired
USB, Gigabit LAN
1200 dpi
1200 dpi
HP ImageREt 3600
PostScript Support
Standard
Language Simulation
800 MHz
RAM
RAM Installed (Max)
512 MB / 1 GB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Max Media Capacity
1100 sheets
Output Trays Capacity
500 sheets
Duty Cycle
100000 pages
Print server - integrated
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP 3
Security Protocols & Features
IPsec
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Power supply - internal
740 Watt
Power Consumption Stand by / Sleep
72 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
15 °C
27 °C
30 - 70%
54 cm
52.2 cm
42 cm
38.5 kg
Width (Shipping)
74.6 cm
Depth (Shipping)
64.4 cm
Height (Shipping)
54.9 cm
Weight (Shipping)
44 kg
