HP 2211x - 21.5" LED Backlit LCD Display 1920 x 1080
HP 2211x LCD-Monitor mit 21,5 Zoll Diagonale und LED-Hintergrundbeleuchtung
Quicklinx: 7MCBWS00 Mfr#: LV916AA#ABU
The HP 2211x offers a perfect combination of screen performance, sleek design, and responsible features with a 54,6 cm (21.5") diagonal LED Backlit LCD panel that can help enhance your workday.
  • Enhance your experience
    The stylish, ultra-slim HP 2211x looks great in your office environment without taking up valuable space. Adjustable tilt settings also enable clear views from many angles so you can be more comfortable and productive at work.
  • Boost your performance
    Get crisp, clear, views on a full HD screen with a 3M:1 dynamic contrast ratio, up to a 170° viewing angle, and fast 5ms response times . As well, DVD-D and VGA inputs enable advanced connectivity.
  • Enjoy extra benefits
    The HP 2211x, with LED backlighting, delivers benefits over CCFL that include: the elimination of mercury, the use of solid state components to enable a thin, robust product, and quick on/off switching times to help save energy.
  • Reduce your impact
    With the use of Mercury-free LEDs and arsenic-free display glass, along with an ENERGY STAR qualification and an EPEAT Silver registration, the HP 2211x can help reduce your environmental impact.
HP 2211x - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
5 ms
Colour Gamut
68%
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
51.9 cm x 15.9 cm x 39.6 cm
3.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV, VCCI, C-Tick, BSMI, CB, CCC, FCC, ISO 9241-307, S Mark, E-Standby
Display Type
Diagonal Size
21.5"
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
68%
Response Time
5 ms
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
3.5 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
30
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
Security Slot Type
Kensington security slot
Power Supply
External
Power Consumption (Typical)
29 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
