Hitachi's CP-AW2503 ultra short throw LCD projector is ideally suited for producing large images in limited spaces. It provides vibrant image quality with cost-effective operation. A suite of advanced features normally found only on higher end models includes High Dynamic Contrast Range, 2 HDMI ports, and Hitachi's original technology Accentualizer that allows the projected image to appear more real by enhancing sharpness, gloss and shade. Along with its light weight and compact design, the CP-AW2503 offers Hitachi's most appreciated installation feature, "Perfect Fit", allowing time saving and ease of installation. As with all Hitachi projectors, you can expect vibrant image quality, cost-efficient operation, and long-lasting reliability. Plus, Hitachi's Intelligent Eco and Saver Modes with ImageCare combine optimal picture performance with energy savings for a lower total cost of ownership.
- Hitachi CP-AW2503 - 3LCD projector - LAN
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 2700 lumens
- Contrast Ratio
- 5000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Bulb type
- 250 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 360 Watt
- 37.6 cm x 36.1 cm x 13.7 cm
- 4.3 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 2700 lumens
- Brightness (Reduced)
- 1800 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 152 cm - 254 cm
- Projection Distance
- 0.4 m - 0.69 m
- Throw Ratio
- 0.2 - 0.3:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Video Bandwidth
- 150 MHz
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 106 kHz
- Bulb type
- 250 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Closed Caption, High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, 16:9 aspect ratio support, input source naming, Wireless Ready, 16:10 aspect ratio support, 4:3 aspect ratio support, AMX Device Discovery, Perfect Fit 2, Template Function, PJMessenger, ImageCare Technology, Cloning Function, Intelligent Eco, accentualiser technology, High Dynamic Contrast Range (HDCR), Crestron Integrated Partner, USB Display, Tabletop Presentation, Wireless Presentation Compatible, Remote control application support
Lens
- Lens Aperture
- F/1.8
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -5/ +5
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input / RGB output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code, security bar, My Screen lock
- cUL, FCC Part 15 B, UL 60950-1
- Power Source
- AC
- Voltage Required
- 360 Watt
- 37.6 cm
- 36.1 cm
- 13.7 cm
- 4.3 kg
- Limited warranty - parts and labour - 3 years
- 0 °C
- 40 °C
