- HANNS.G HX193DPB - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 40000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.2 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare
- 42.2 cm x 6.6 cm x 38.9 cm
- 4.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV, BSMI, cUL, NOM, CB, FCC
- Display Type
- Diagonal Size
- 19"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- 4.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D (HDCP) , Audio line-in
Mechanical
- Tilt
- VESA Mounting Interface
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable
- Power Consumption (Typical)
- 21.1 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
