GO Lamp for VLT-SD105LP. Lamp module for MITSUBISHI SD105U projector. Type = NSH. Power = 160 Watts. Lamp Life = 2000 Hours. Now with 2 years warranty.
- GO Lamps projector lamp
- Product Type
- Projector lamp - NSH - 160 Watt
- OEM Manufacturer Lamp Equivalent
- VLT-SD105LP, Mitsubishi VLT-SD105LP
- Bulb life cycle
- 2000 hour(s)
- 2-year warranty
- Designed For
- Mitsubishi SD105U
- Product Type
- Projector lamp
Lamp
- NSH
- Capacity
- 160 Watt
- Life Cycle
- 2000 hour(s)
- Limited warranty - 2 years
- Designed For
- Mitsubishi SD105U
