Gigabyte Brix BXi7H-5500 Ultra Compact PC Kit - Barebones
Quicklinx: B913WS00 Mfr#: GB-BXI7H-5500
  • IEEE 802.11n
  • Bluetooth 4.0
  • Core i7
GIGABYTE engineers developed an ultra compact PC with a stylish glass surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a high standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
  • Dual display
    With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
  • Flexible compact PC kit
    The BRIX is sold as a DIY PC kit, shipping with a NGFF M.2 Wi-Fi module pre-installed, plus a power adapter and cable conforming to local standards. Requiring only system memory and mSATA SSD, the BRIX gives users the flexibility to independently choose integrated storage and system memory size, without the trouble of sourcing components that are not widely available on the retail market.
  • VESA support
    Bundled with a VESA bracket, the BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
  • Support Near Field Communication technology
    The GIGABYTE BRIX is equipped with NFC technology that can be paired with NFC devices. Up to 8 profiles allow users to easily set any number of commands to be executed. NFC technology works in tandem with your enabled devices to secure, simplify and expedite everyday tasks such as accounts login and payment authorization.
Gigabyte BRIX s GB-BXi7H-5500 (rev. 1.0) - Ultra Compact PC Kit - Core i7 5500U 2.4 GHz - 0 GB - no HDD
PC barebone - Ultra Compact PC Kit
1 x Intel Core i7 (5th Gen) 5500U / 2.4 GHz (, up to 3 GHz, (Dual-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
4 MB
Cache Per Processor
4 MB
RAM
0 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 5500
Audio Output
Integrated
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5, NFC
AC 120/230 V
OS Provided
No operating system
10.76 cm x 11.44 cm x 4.68 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Max Turbo Speed
3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
4 MB
Cache Per Processor
4 MB
RAM
Installed Size
0 GB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Integrated
Ethernet Controller
Realtek RTL8111G
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac, NFC
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x mSATA , 1 (total) / 0 (free) x M.2 Card , 2 (total) / 2 (free) x SO-DIMM 204-pin
4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front)
VESA wallmount adapter
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
AC 120/230 V
Operating System / Software
OS Provided
No operating system
10.76 cm
11.44 cm
4.68 cm
35 °C
