Generic 1537L 38CM 15IN SECURETOUCH RM $
Quicklinx: 820RWS00 Mfr#: E731919
The 1537L open-frame touchmonitor has a compact form factor with thin borders and multiple mounting options for easy integration. The 1537L with SecureTouch transactional single touch technology offers best-in-class optical performance, in combination with a high quality panel along with a unique, injection-molded minibezel with a virtually invisible water-resistant seal. SecureTouch monitors use a 3 mm chemically strengthened glass touch sensor.
Elo Open-Frame Touchmonitors 1537L SecureTouch - LCD monitor - 15"
LCD monitor - 15" - touchscreen
Touch-screen
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Brightness
230 cd/m²
Contrast Ratio
500:1
Response Time
14.5 ms
Colour Support
16.2 million colours
Input Connectors
VGA
Screen Coating
Anti-glare
Voltage
Black, steel
33.6 cm x 4.1 cm x 26.4 cm
3 kg
UL, TUV GS, VCCI, C-Tick, cUL, SEMKO, IC, FCC, RoHS
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
15"
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Brightness
230 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
14.5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
60.2 kHz
Horizontal Viewing Angle
+70 / -70
Vertical Viewing Angle
+60 / -55
Screen Coating
Anti-glare
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature, phase, clock
OSD Languages
English, German, French, Spanish, Japanese
SecureTouch Surface Wave
Black, steel
3 kg
Input
Touch-screen - touchscreen
VGA , Serial , USB
Mechanical
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Wall mountable
1 x VGA cable , 1 x serial cable , 1 x USB cable
Mounting Kit
Included
Backlight Life
30,000 hours
MTBF
50,000 hour(s)
Power Supply
External
Input Voltage
Power Consumption (Typical)
30 Watt
Limited warranty - 3 years
20 - 80%
