EVGA 430W White 80PLUS Certified PSU
Quicklinx: 96QGWS00 Mfr#: 100-W1-0430-KR
When building on a budget, the EVGA 430W 80 PLUS is a great choice at a low cost. Supporting 34A on a single +12V rail provides more options without having to reduce your component requirements. Save space with the 430W's compact design, well-placed power switch and fully sleeved cables. The 430W offers the connections and protections needed for basic system builds. With a standard 3 year warranty and ultra quiet fan design the 430W will be a great asset for your next build on a budget.
CABLE LENGTH
  • ATX CABLE 1x 550mm
  • EPS CABLE 1x 600mm
  • PCIE CABLE 1x 550mm
  • SATA CABLE 2x 450mm, 570mm
  • FOUR-PIN PERIPHERAL CABLE 1x 450mm, 570mm, 690mm (f)
  • FLOPPY CABLE 1x 120mm
  • AC POWER 1x 1200mm (m)
FEATURES
  • Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
  • 3 Year Warranty (More Info)
  • Quiet and Intelligent Auto Fan for near-silent operation
EVGA - power supply - 430 Watt
Power supply - internal
1.8 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
430 Watt
Output Current
+5V - 15 A , +3.3V - 24 A , +12V - 34 A , -12V - 0.3 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Modular Cable Management
15 cm x 14 cm x 8.5 cm
3-year warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
430 Watt
Output Current
Efficiency
80%
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
UL, TUV, FCC, RoHS, WEEE, cULus
Limited warranty - 3 years
50 °C
15 cm
14 cm
8.5 cm
1.8 kg
