High quality, bright and vibrant images
This LCD projector effortlessly displays bright images with vivid colours for a crisp, clear picture: ideal for presentations and moving images, and is aided by the 10,000:1 contrast ratio. With an HDMI input, high definition video and audio content are easily played with the same high quality you would expect from the world's number one projector manufacturer .
Colour Light Output (CLO)
CLO is an important way of measuring a projector's ability to deliver colour and, like all Epson projectors, this model has an equally high White and Colour Light Output for a bright picture with vivid colours.
User-friendly
Thanks to its manual keystone slider – unique to Epson – and automatic vertical keystone correction, this projector is quick and simple to set up. No matter the angle of the projector, you can easily align the projection to ensure a straight and correct image. The Colour Universal Design makes operating the projector easier, thanks to new LED colours and menu icons on the projector's control panel.
Wireless projector
The optional wireless connectivity allows you to show content easily from a range of devices without being connected to the projector via a cable.
Bright LCD projector
The Wi-Fi LCD projector for bright, vivid images in small offices and classrooms.
- Epson EB-S17 - 3LCD projector - portable
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness (White)
- 2700 lumens
- Brightness (Colour)
- 2700 lumens
- Contrast Ratio
- 10000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Bulb type
- E-TORL UHE 200 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 270 Watt
- 29.7 cm x 24.4 cm x 8.7 cm
- 2.5 kg
- 3LCD projector
- Built-in Devices
- Speaker
Projector
- 2700 lumens
- Contrast Ratio
- 10000:1
- Image Size
- 76 cm - 889 cm
- Throw Ratio
- 1.45 - 1.96:1
- Digital Zoom Factor
- 1.35x
- Resolution
- SVGA - SVGA (800 x 600)
- 4:3
- Bulb type
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, USB host function, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Direct Power On, Direct Power Off, Dynamic Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.44
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232C , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Voltage Required
- 270 Watt
- Power Consumption Stand by
- 0.47 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor
- 29.7 cm
- 24.4 cm
- 8.7 cm
- 2.5 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 29 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
