Designed to fulfill the specific requirements of the bigger location, this top-of-the-range large venue installation projector has a WUXGA native resolution, making it ideal when presenting large-sized visuals and displays. And with the addition of 1080p/24 frames per second (fps) processing, audiences will be able to watch smoother, more cinematic images.
- Epson EB-G5750WUNL - 3LCD projector - no lens - 802.11a/g wireless / LAN
- 3LCD projector - 1080p
- Built-in Devices
- Speaker
- Brightness
- 4500 lumens
- Contrast Ratio
- 1500:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Lens
- No lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- UHE 330 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11a/g wireless / LAN
- Digital Video Standard
- Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
- Video Modes
- 1080p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 47 cm x 31.2 cm x 13.5 cm
- 6.8 kg
- 3-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 4500 lumens
- Brightness (Reduced)
- 3600 lumens
- Contrast Ratio
- 1500:1
- Image Size
- 127 cm - 762 cm
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Bulb type
- UHE 330 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Slovenian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan, Japanese, Korean, Malay
- EPSON 3LCD technology, Crystal Clear Fine (C2 Fine)
Lens
- No lens
- Keystone Correction Direction
- Lens Shift Type
- Manual
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, DVI
- Video Modes
- 1080p
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11a
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 7 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 3 x audio line-in - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - BNC , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x component video / RGB input - BNC x 5 , 1 x DVI-D - 24+1 pin digital DVI
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- AC 120/230 V
- 47 cm
- 31.2 cm
- 13.5 cm
- 6.8 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year
- Sound Emission
- 39 dB
- Sound Emission (Economic Mode)
- 33 dB
