Large projections
You can easily achieve a large projected widescreen image of up to 100 inches from a very short distance thanks to the EB-475W's ultra-short-throw capabilities.
Easy installation
Epson has designed this projector to be quick and easy to use. You simply turn on and plug in with the USB functionality. Horizontal keystone correction enables you to easily align straight images and it also has a 16W built-in speaker, so no need to attach to external audio devices.
Easily controlled
The EB-475W can be turned on and off with a wall switch using the direct power on/off function, and with quick-start and instant-off functions, no warm-up or cool-down time is needed. For convenient wall-mounted control at the front of the classroom, the projector can be connected to the Epson ELPCB01 Control and Connection Box.
Low costs
Running costs are kept low thanks to a long lamp life of 4,000 hours or four years, in eco mode, and 5,000-hour filter life.
High-quality images
Epson's 3LCD technology ensures high-quality images with its equally high White and Colour Light Output for vivid, natural colours and deep blacks, even in daylight. Presentations can be more engaging by plugging in the Epson ELP-DC06 USB Visualiser to show 3D objects close-up while the HDMI input also means high-definition content can be displayed with maximum clarity.
Bright ultra-short-throw projector
Deliver high-quality presentations and reduce shadows with Epson's 2,600-lumen ultra-short-throw projector.
- Epson EB-475W - 3LCD projector - LAN
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 2600 lumens
- Brightness (Colour)
- 2600 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 215 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 1080p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- 275 Watt
- 36.7 cm x 14.3 cm x 37.5 cm
- 5.2 kg
- 3-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 2600 lumens
- 2600 lumens
- Brightness (Reduced)
- 1800 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 152 cm - 254 cm
- Throw Ratio
- 0.27:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Display Format
- 1,024,000 pixels (1,280 x 800) x 3
- Bulb type
- 215 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -5/ +5
- Horizontal Keystone Correction
- -5/ +5
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
- 1080p
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
Input Device
- External
- 1 x HDMI input - 19 pin HDMI Type A , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x component video input , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- 275 Watt
- Power Consumption Operational (Standby)
- 0.27 Watt
- Software Included
- Drivers & Utilities
- 36.7 cm
- 14.3 cm
- 37.5 cm
- 5.2 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 28 dBA
