High brightness: Powered by 3LCD technology, the projector delivers a vibrant, high-quality XGA picture, thanks to an equally high White and Colour Light Output of 4,000 lumens and a contrast ratio of 2,500:1
Easy to use: Setting up the EB-1880 is easy. The projector automatically searches for the picture source, so you don't need to do anything after plugging in your laptop. Aligning the picture takes just seconds as vertical keystone correction is automatic and horizontal keystone can be adjusted using an intuitive slider.
Helpful features: Sound is provided by a built-in speaker delivering up to 10W, while the clever 3-in-1 USB display feature means just one cable is all that's needed for audio, visual and mouse control.
Outstanding versatility: The EB-1880 has a wide range of inputs, including HDMI, and features a direct connection for Epson's ELP-DC06 USB document camera.
Great flexibility: Light and compact, the EB-1880 is ideal for ceiling or desktop installation, while the projector's extra-long adjustable foot means it's suitable for low tables too.
Low cost of ownership: Low power consumption and a long lamp life combine to deliver a low total cost of ownership, while remote network management helps keep maintenance costs down by removing the need for physical checks.
Feature-rich bright projector
Ideal for corporate and educational applications, this compact projector offers high brightness and lots of helpful features at an affordable price.
- Epson EB-1880 - 3LCD projector - LAN
- 3LCD projector
- Brightness
- 4000 lumens
- Brightness (Colour)
- 4000 lumens
- Contrast Ratio
- 2500:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 16.7 million colours
- Bulb type
- E-TORL UHE 275 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Output
- RGB
- 363 Watt
- 34.5 cm x 26.3 cm x 9.3 cm
- 3.3 kg
- 3-year warranty
- 3LCD projector
Projector
- Brightness
- 4000 lumens
- Contrast Ratio
- 2500:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.38 - 2.24:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- Bulb life cycle
- OSD Languages
- Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Slovenian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan, Japanese, Korean, Malay
- EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Video Output
- Analogue Video Signal
- RGB
Input Device
- External
- 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- 363 Watt
- Power Consumption Operational (Standby)
- 0.27 Watt
- Software Included
- Drivers & Utilities
- 34.5 cm
- 26.3 cm
- 9.3 cm
- 3.3 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year
- Sound Emission
- 39 dB
- Sound Emission (Economic Mode)
- 35 dB
