Edimax POE NETWORK CAMERA W/NIGHT VISION
Quicklinx: 82SVWS00 Mfr#: IC-3030iPoE
  • SDHC Memory Card
The Edimax IC-3030i series is tailor made to stream live video footage of your home wired or wirelessly over a network connection. You can check upon the security of your home, family, pets, or assets with the bundled viewer, which allows you access up to 16 Edimax network cameras simultaneously.
The Edimax IC-3030i series is perfect for capturing brilliant and clear video images under low light conditions. What makes it suitable for operating in such environments is its built-in IR (infrared) LEDs and light sensor. The IR LEDs are able to illuminate up to 4 meters effectively, making the IC-3030i series suitable for almost all security and surveillance applications.
  • Live video streaming
  • Night vision for crisp and clear images at night
  • Triple-mode video compression (H.264, MPEG-4 and M-JPEG)
    With triple-mode video compression support, the Edimax IC-3030i series can ensure high video quality and high frame rate video streaming. Users can select H.264, MPEG-4 or M-JPEG video compression mode depending on preference and network settings.
  • Motion-triggered snapshots and pre- and post-recording
    The IC-3030i series is designed with a powerful multi-area motion detection system. When motion is detected in the specified areas, the network camera will immediately take a snapshot of the detected motion and send the snapshot to the user via email or FTP. The multi-area motion detection function also works with the network camera's pre- and post-recording feature. When motion is detected, the IC-3030i series is able to produce video footage of the monitored area up to 5 seconds before the detected motion.
  • SDHC/SD card slot for local storage
    The IC-3030i series features an SDHC/SD card slot for local data storage. Should the network or Internet connection fail, the Edimax IC-3030i series is able to save snapshots and videos locally on a SDHC or SD card.
  • Supports 2-way audio
    The Edimax IC-3030i series is designed with 2-way audio support. By connecting speakers and a microphone to the network camera, users can remotely communicate with people at the site where the network camera is installed, or even ward off an intruder when necessary.
Edimax IC-3030iPoE - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: two-way audio capability, built-in microphone
8 cm x 4.3 cm x 11.3 cm
Wired
Camera
Colour - Day&Night
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS 1.3 MP
Focal Length
5 mm
Focus Adjustment
Manual
Lens Iris
F/2.8
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Power over Ethernet, SDHC-card slot, Video Snapshot mode, Motion Detection Technology, upgradable firmware
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired
8 cm
4.3 cm
11.3 cm
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, AVI, MJPEG, H.264
Motion Detection
Infrared LEDs
Frame Rate (max)
RAM
64 MB
Flash Memory
4 MB
Image Sensor
1.3 MP CMOS
Lens Construction
Focal Length
5 mm
Lens Iris
F/2.8
Focus Adjustment
Manual
Network Interface
Network Protocols
DDNS, FTP, UPnP
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-out
Supported Memory Cards
SDHC Memory Card
FCC Class B certified, RoHS
Power Requirements
DC 12 V / PoE
Power adapter - external
Software Included
Drivers & Utilities
Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Pentium 4 - 2.4 GHz HD 128 MB
Relative Humidity (operating)
