The ES-3305P V2 is plug-and-play and supports a wide range of network protocols. Installation and network management is quick and straightforward, and clear and convenient LED indicators display easy to read port and switch status. Along with the Fast Ethernet speeds critical for next-generation network applications, the ES-3305P V2 offers environmental efficiency. To comply with the IEEE802.3az standard, the ES-3305P V2 provides power saving functionality to reduce energy consumption and save costs.
Easy to use
The ES-3305P V2 is plug-and-play and supports a wide range of network protocols. Installation and network management is quick and straightforward, and clear and convenient LED indicators display easy to read port and switch status. -
IEEE Energy Efficient Ethernet (EEE) compliance
Along with the Fast Ethernet speeds critical for next-generation network applications, the ES-3305P V2 offers environmental efficiency. To comply with the IEEE802.3az standard, the ES-3305P V2 provides power saving functionality to reduce energy consumption and save costs. -
Inactive link detection
When a network device is shut down and/or an inactive link is detected, the power usage adjustment feature automatically reduces power usage. The switch's power consumption will be dynamically adjusted according to the link status and the number of active network devices. -
Supports auto-negotiation
Each of the ES-3305P V2's ports automatically detect whether connected network devices are running at 10 Mbps or 100 Mbps and half-duplex or full-duplex mode, and adjusts the speed and mode accordingly ensuring easy and hassle-free operation. -
Supports non-blocking wire speed
The ES-3305P V2 forwards and receives traffic seamlessly with its non-blocking wire-speed. Every port of the ES-3305P V2 supports speeds up to 200Mbps in full-duplex mode simultaneously, providing full wire speed to connected devices and allowing you to run a high speed network smoothly.
- Edimax ES-3305P V3 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- MAC Address Table Size
- 1K entries
- Auto-negotiation, store and forward, half duplex mode, full duplex mode, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
- 8.8 cm x 8.8 cm x 2.5 cm
- 82 g
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- 1K entries
- RAM
- 48 KB
- Status Indicators
- Power, link/activity
- 5 x 100Base-TX RJ-45
- Power Device
- External power adapter
- 2 Watt
- Plug and Play, FCC Class B certified
- 8.8 cm
- 8.8 cm
- 2.5 cm
- 82 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
