VigorSwitch G2100
8-Port Gigabit Layer 2+ Managed Switch with 2 SFP Uplink Ports
The VigorSwitch G2100 is a high-performance, Layer 2+ Managed Ethernet switch. With 8 RJ-45 Gigabit LAN ports, it's ideal for adding network ports to a DrayTek Vigor router. The enterprise-level features allow your business to improve network stability and security.
The VigorSwitch G2100 works superbly in standalone mode, but designed for centralised management, it can be provisioned and monitored by one of DrayTek’s central management platforms. These include the VigorACS management platform, VigorConnect on-site management and DrayTek’s router-based switch management These platforms allow you to drastically reduce the setup time required for a complex network and configure an entire DrayTek network remotely.
Central Management
Managing a VigorSwitch through VigorACS
Central Switch Management with a DrayTek Vigor Router
Dynamic MAC-based VLAN
Surveillance & Voice Auto VLAN
Advanced Layer 2+ Routing Features
ONVIF IP Camera Management
IP Conflict Detection & Prevention
Quality of Service & Bandwidth Control
Network Security and Management Features
Rack Mountable & Silent
Great security features
Protect your network against unauthorized access and network problems with DrayTek's IP conflict prevention, 802.1X port authentication, DHCP Snooping, and Access Control Lists. -
Advanced Layer 2+ Routing features
Expand your network with support for Layer 3 features such as Static Routes and VLAN Routing, to connect separate networks through the VigorSwitch. -
Rack-mountable and silent
Fanless and silent, the switch is ideal for use in a quiet office or home environment. -
IP camera management
Manage IP cameras easily with detection and management of ONVIF cameras. Use PoE device check, auto-generated IP camera topology and camera snapshots to detect and troubleshoot problems.
- Draytek VigorSwitch G2100 - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - L2+ - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 + 2 x Gigabit SFP (uplink)
- Performance
- Forwarding performance (64-byte packet size): 14.88 Mpps , Switching capacity: 20 Gbps
- Capacity
- Virtual interfaces (VLANs): 256 , QoS queues: 8 , Total link aggregation groups: 4
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, static IP routing, IGMPv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2
- Flow control, auto-negotiation, load balancing, VLAN support, IGMP snooping, Syslog support, traffic shaping, E-mail alert, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, IPv4 support, LLDP support, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Strict Priority Queuing (SPQ), port isolation, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), ONVIF support, DiffServ Code Point (DSCP) support, Protocol-based VLANs support, IP source guard, layer 2+ switching, Link Aggregation, scheduler, rate limit, Authentication, Authorization and Accounting (AAA), IGMP querier, VLAN Double Tagging (Q-in-Q), Voice VLAN, VLAN management, LLDP-MED, Private MIB, Guest VLAN, Denial of Service (DoS) protection, DSCP based CoS, MAC based VLAN, loopback detection, Unknown Storm Control, 4.1Mbit packet buffer, Address Conflict Detection, OpenVPN client, DSCP based QoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V
- 27 cm x 18.1 cm x 4.4 cm
- 1.78 kg
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 8K entries
- 9KB
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2), internal user database
- 8 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP , 1 x console RJ-45 management
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 18 Watt
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- FCC
- Localisation
- United Kingdom
- 27 cm
- 18.1 cm
- 4.4 cm
- 1.78 kg
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
