The VigorAP 700 is a draft N wireless access point and it provides the ultimate industry standard access to corporate network, the Internet, e-mail and residential wireless network. With mobile workforce demands, VigorAP 700 delivers reliable and secure wireless local area networks (WLANs). The extended range is enabled through its simplified but robust management and configuration.
DrayTek implements intelligent wireless prioritization technology on VigorAP 700. VigorAP 700 supports Wi-Fi Multi Media standard (WMM). It is a standard created to define Quality of Service (QoS) in Wi-Fi networks. It is a precursor to the upcoming IEEE 802.11e WLAN QoS draft standard, which is meant to improve audio, video and voice applications transmitted over Wi-Fi. WMM adds prioritized capabilities to Wi-Fi networks and optimizes their performance when multiple concurring applications, each with different latency and throughput requirements, compete for network resources.
- Draytek VigorAP 700 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- 12.7 cm x 9.6 cm x 3 cm
- 1-year warranty
- 12.7 cm
- 9.6 cm
- 3 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, wireless bridge mode
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n (draft 2.0)
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45
- Power Device
- External power adapter
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 90%
