The Ideal DSL Router with VPN for Small Business and Remote Working
DrayTek’s Vigor 2865 series Multi-WAN Firewall VPN routers are ideal for Superfast VDSL Broadband and Ethernet-based FTTP Fibre Broadband. With Gigabit throughput, Quality of Service, VPN client/server, comprehensive Firewall and Content Filtering controls.
Wi-Fi is available on ‘ac’ models and the integrated 4G+ LTE modem on ‘Lac’ models takes full advantage of mobile broadband. The Vigor 2865 series provides a reliable, flexible, and secure networking solution, that’s ideal for Home Offices, Small Business and Satellite Offices.
VDSL and Ethernet Load Balancer
Route Policy - Powerful Routing Management
Integrated LTE 4G/3G Modem
Constant Connectivity - Dual-SIM LTE
AC1300 Wireless LAN with Mesh
Ideal VPN router for SMB
Connect VPNs from behind NAT with DrayTek's VPN Matcher
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
5+1 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
High Availability - Hardware Failover
DrayDDNS - DrayTek Dynamic DNS Address
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
- Draytek Vigor 2865Lac - router - DSL/WWAN - Wi-Fi 5 - desktop
- Router - DSL modem / wireless cellular modem - 6-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, VDSL, ADSL2, ADSL2+, VDSL2, Vplus 35b
- Mobile Communication Protocol
- LTE
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- Concurrent VPN tunnels: 32 , NAT sessions: 50000 , Concurrent SSL VPN tunnels: 16
- PPTP, L2TP, IPSec, PPPoE, ARP, FTP, DHCP, DNS, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6
- Routing Protocol
- RIP, BGP, GRE, static IPv4 routing, static IPv6 routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
- VoIP Protocols
- H.323, SIP
- Firewall protection, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, IPv6 support, VPN passthrough, High Availability, Wireless Distribution System (WDS) support, URL filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, SMS alert, hidden SSID, reset button, bandwidth control, IPv4 support, DNS server, port triggering, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, application filtering, IGMP proxy, 802.1x authentication, Type of Service (ToS), Push Button Configuration (PBC), L2TP passthrough, band steering, WDS bridge, Web Filtering, IGMP fast leave, Airtime Fairness, 2x2 MU-MIMO technology, L2TP over IPSec, client isolation, DMZ support, VLAN Tagging, port-based VLAN, port-based QoS, WDS repeater mode, multiple PVC support, broadcast threshold, DNS filtering, 2x2 MIMO technology, DNSSEC support, WLAN scheduling, DSCP based QoS, Brute Force Protection
- IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.1x, UPnP
- 24.1 cm x 16.6 cm x 4.6 cm
- Localisation
- United Kingdom, Ireland
- Router - 6-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MPPE, AES, SSL, SHA-1, WPA, WPA2, IKEv2, 256-bit SHA, WEP
- Authentication Method
- RADIUS, X.509 certificates, TACACS+, LDAP, internal user database, XAUTH authentication
- Status Indicators
- WAN, DMZ, link/activity, USB, DSL, 5 GHz, 2.4 GHz, QoS
Line Properties
- Framing Format
- ANSI T1.413
Communications
- LTE
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.5, ITU G.993.2, ITU G.993.5, ITU G.992.3
- Max Transfer Rate
- 300 Mbps
IP Telephony
- VoIP Protocols
- H.323, SIP
- LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
- Expansion Slots
- 2 SIM
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Cables Included
- 1 x modem cable
- Localisation
- 24.1 cm
- 16.6 cm
- 4.6 cm
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
