The Vigor 2860 series (including the Vigor 2860n and Vigor 2860Vn) is our new router/firewall which can support either ADSL or VDSL (BT Infinity™/FTTC). This makes the Vigor 2860 ideal ideal for users with ADSL now who might upgrade to VDSL later. Alternative WAN ports can insead provide connectivity to Ethenet feeds, secondary xDSL modems or a 3G cellular service using a USB adaptor. This latest router series includes support for professional features such as VLAN tagging, Gigabit Ethernet and built-in WiFi ('n' models).
Packed with professional-level features, the Vigor 2860 series offers truly comprehensive DSL connectivity and security. Compatible with all UK variants of ADSL (including ADSL2+ and Annex M), VDSL and VDSL2, the Vigor 2860 can also be used for cable-modem, leased line and EFM applications using its Gigabit Ethernet WAN port. On VDSL, the Vigor 2860 series supports the very latest services for speeds up to 80Mb/s (depending on line quality and length).
The specifications cover many functions that are required by modern day businesses, including secure but easy to apply firewall, comprehensive VPN capability, Gigabit LAN ports, USB ports for 3G/4G mobile dongles, FTP and Samba server and network printers, VLAN for flexible workgroup management, and much more.
You have the flexibility of migrating to VDSL2 when your ISP/Telco upgrades from current ADSL2+ technology. Besides, in case you move to a new location where VDSL2 is not available, your router can fall back to ADSL2+.
The Vigor 2860Vn-plus variant provides two analogue phone ports and an analogue line port provide full PSTN and VoIP integration via both the Internet (VoIP) and your regular analogue line. You can connect 1 or 2 regular telephones and the can be used independently and simultaneously for both incoming and outgoing calls.
As well as the two telephone ports, a third port, the Analogue Line port, connects into your regular analogue line (PSTN/POTS*). This then gives the telephones access to your analogue line to allow you to make calls as well as your VoIP facility (you can select the PSTN line instead of VoIP by dialling #0). Incoming calls are automatically switched through to your telephone(s) (either one or both) so that each phone can be used for both VoIP and POTS calls. Both telephones plugged into your router have access to VoIP and your analogue line. In addition, using the 'Digit-Map' facility you can set rules about particular call destinations using either the POTS line or your SIP/VoIP service. For example, local calls can be routed via your PSTN line (if you have a free calls package for example) whereas international calls can go via your preferred VoIP provider; there is flexibility to have several digit-map rules.
As well as connecting with a SIP/VoIP gateway directly (such as DrayTEL), the Vigor2860Vn-plus can register its phones as extensions on a remote IP PBX, such as DrayTek's Vigor IPPBX products, so this is an idea teleworker solution.
*POTS = Plain Old Telephone Service - The traditional analogue phone voice line in your home/office, e.g. B.T. That line may also be carrying your ADSL data signal.
Fail-over and Load Balancing with a second Gigabit Ethernet WAN
The Gigabit Ethernet WAN port caters for any type of Internet access, including ADSL, Cable or Satellite broadband. You can then use both WAN 1 and WAN 2 for Fail-over, ensuring that you will always have an access to the Internet even if one of the WAN fails, or for Load Balancing so the 2 WANs share Internet traffic requirements of your organization. -
Comprehensive VPN
For remote teleworkers and inter-office links, Vigor2860 series provide up to 32 simultaneous VPN tunnels (such as IPSec/PPTP/L2TP protocols) for secure data exchange and communication. With a dedicated VPN co-processor, the hardware encryption of AES/DES/3DES and hardware key hash of SHA-1/MD5 are seamlessly handled, thus maintaining maximum router performance. Teleworkers can be authenticated directly with your LDAP server if preferred. The Vigor2860 series are equipped with physical DSL port and Gigabit Ethernet port for WAN load-balancing and backup. The VPN trunking (VPN load-balancing and VPN backup) are hence implemented on Vigor2860 series. With VPN trunking, you can create multiple WAN connections to a remote site in order to increase bandwidth. The VPN trunking also can allow you to have failover (backup) of VPN route through a secondary WAN connection. With SSL VPN, Vigor2860 series let teleworkers have convenient and simple remote access to central site VPN. The teleworkers do not need to install any VPN software manually. From regular web browser, you can establish VPN connection back to your main office even in a guest network or web cafe. The SSL technology is same as the encryption that you use for secure web sites such as your online bank. The SSL VPNs can be operated in either full tunnel mode or Proxy mode. After F/W 3.7.3, the Vigor2860 series allows up to 16 simultaneous incoming users. -
Centralized Management
With F/W 3.7.3, the embedded Central VPN Management (CVM) will let network administrator register up to 16 remote routers but run concurrent remote management over 8 remote routers. -
AP Management
APM provides the 3-step installation, plug-plug-press, and then wireless clients are able to enjoy surfing internet. Moreover, through the unified user interface of Draytek routers, the status of APs is clear at the first sight. -
Multi-subnet
With the 6-port Gigabit switch on the LAN side provides extremely high speed connectivity for the highest speed local data transfer of any server or local PCs. The tagged VLANs (802.1q) can mark data with a VLAN identifier. This identifier can be carried through an onward Ethernet switch to specific ports. The specific VLAN clients can also pick up this identifier as it is just passed to the LAN. You can set the priorities for LAN-side QoS. You can assign each of VLANs to each of the different IP subnets that the router may also be operating, to provide even more isolation. The said functionality is tag-based Multi-subnet.
- Draytek Vigor 2860n-Plus - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 6-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, VDSL2
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- VPN tunnels: 32 , SSL VPN tunnels: 16 , UPnP sessions: 30 , Simultaneous NAT sessions: 50000
- PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, FTP, DHCP
- Routing Protocol
- RIP-2, IGMPv2, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
- Firewall protection, DMZ port, NAT support, VPN support, load balancing, VLAN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, DiffServ support, E-mail alert, print server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Access Point operational mode, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Samba support, FTP server, Multiple SSID support, DNS proxy, bandwidth control, DHCP relay, anti-spoofing protection, DHCP client, Management Information Base (MIB), tagged VLAN, IM/P2P filter, DNS caching, Content Security Management (CSM)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3ah, IEEE 802.11e, IEEE 802.11n, UPnP
- 24.1 cm x 16.5 cm x 4.4 cm
- 2-year warranty
- Wireless router - 6-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
- Authentication Method
- RADIUS, X.509 certificates, Radio Service Set ID (SSID)
- Built-in Devices
- Led panel
- Status Indicators
- Power, WLAN, WAN, link/activity, USB, ADSL, VPN
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT) Annex A, ITU G.992.1 (G.DMT) Annex B, ITU G.992.3 Annex A, ITU G.993.2, ITU G.992.5 Annex A, ITU G.992.5 Annex B, ITU G.992.3 Annex B
- LAN: 6 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- 24 Watt
- 24.1 cm
- 16.5 cm
- 4.4 cm
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
