Projector lamps have to withstand enormous pressure and massive heat to generate the light output required for projected displays, such as presentations and videos.
The lamp itself is a complex mix of chemicals, including mercury, and precision electronics packaged into a sealed glass bulb. The unit is expected to operate at above 8000k (hotter than the sun! ) and to withstand high pressure, in excess of 200 bar.
- Diamond Lamps projector lamp
- Product Type
- Projector lamp - 230 Watt
- OEM Manufacturer Lamp Equivalent
- V13H010L57, ELPLP57
- Bulb life cycle
- 3500 hour(s)
- 4-month warranty
- Product Type
- Projector lamp
Lamp
- Capacity
- 230 Watt
- Life Cycle
- 3500 hour(s)
- Limited warranty - parts and labour - 4 months
