Dell Ultrasharp U2723QE 27" 3840x2160 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: H662WS00 Mfr#: DELL-U2723QE
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, USB-C, HDMI
More than 50 In Stock
£482.60 ex VAT
£579.12 inc VAT
Be your most productive on a 27 inch monitor with brilliant color and contrast that features the IPS Black technology and a connectivity hub.
  • Exceptional contrast
    Experience incredible color and superior black performance with a contrast ratio of 2000:1 on the 27" 4K monitor with IPS Black technology.
  • Enhanced eye comfort
    ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color.
  • True brilliance
    See fine details on this 4K monitor and enjoy truer-to-life color with 98% DCI-P3 and VESA DisplayHDR 400.
  • Designed with purpose
    With a premium platinum finish and an elegant cable management system made to reduce clutter, it's the monitor built to match any workspace.
  • Easy to use
    Navigate the menu and adjust screen settings with a convenient joystick control.
  • Built for comfort
    Tilt, swivel, pivot and adjust the height of your monitor so you can work however you're most comfortable.
  • Environmental standards
    This monitor uses 85% PCR (Post-consumer Recyclable) plastic in the design and meets the latest environmental standards such as ENERGY STAR and TCO Certified Edge, and is EPEAT Gold.
Dell UltraSharp U2723QE - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
25.9 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
400 cd/m²
Contrast Ratio
2000:1 / 2000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
61.14 cm x 18.5 cm x 38.518 cm
6.64 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
RoHS, BFR-free, PVC-free
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
27"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163.18
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, arsenic-free glass, Delta E<2 calibration, 3-sided bezeless
61.14 cm x 18.5 cm x 38.518 cm - with stand (lowest position)
6.64 kg
HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
1 x USB-C to USB-C cable - 1 m , 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to B
Security Slot Type
Kensington security slot
Input Voltage
25.9 W
25.9 kWh/1000h
Power Consumption HDR (On mode)
37.7 kWh/1000h
Power Consumption (Max)
220 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand (lowest position) - width: 61.14 cm - depth: 18.5 cm - height: 38.518 cm - weight: 6.64 kg , Without stand - width: 61.14 cm - depth: 5.433 cm - height: 35.301 cm - weight: 4.48 kg
Shipping Weight
9.53 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Premium Panel Exchange
Bundled Services
35 °C
10 - 80% (non-condensing)
Accessories (1)
H662 Dell Dual Monitor Stand - MDS19 In Stock £149.14
Other bundles (4)
H662 Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £163.47
H662 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.58
H662 Dell SB521A Magnetic Sound bar In Stock £35.35
H662 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.51
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Interfaces: HDMI
Brand: Dell
