Be your most productive on a 27 inch monitor with brilliant color and contrast that features the IPS Black technology and a connectivity hub.
Exceptional contrast
Experience incredible color and superior black performance with a contrast ratio of 2000:1 on the 27" 4K monitor with IPS Black technology. -
Enhanced eye comfort
ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color. -
True brilliance
See fine details on this 4K monitor and enjoy truer-to-life color with 98% DCI-P3 and VESA DisplayHDR 400. -
Designed with purpose
With a premium platinum finish and an elegant cable management system made to reduce clutter, it's the monitor built to match any workspace. -
Easy to use
Navigate the menu and adjust screen settings with a convenient joystick control. -
Built for comfort
Tilt, swivel, pivot and adjust the height of your monitor so you can work however you're most comfortable. -
Environmental standards
This monitor uses 85% PCR (Post-consumer Recyclable) plastic in the design and meets the latest environmental standards such as ENERGY STAR and TCO Certified Edge, and is EPEAT Gold.
- Dell UltraSharp U2723QE - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Power Consumption (On mode)
- 25.9 W
- USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1554 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 2000:1 / 2000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% Rec 709, 100% sRGB, 98% DCI-P3
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 61.14 cm x 18.5 cm x 38.518 cm
- 6.64 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- RoHS, BFR-free, PVC-free
- 3-year warranty
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163.18
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Mercury free, arsenic-free glass, Delta E<2 calibration, 3-sided bezeless
- 61.14 cm x 18.5 cm x 38.518 cm - with stand (lowest position)
- 6.64 kg
- HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
- Cables Included
- 1 x USB-C to USB-C cable - 1 m , 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to B
- Security Slot Type
- Kensington security slot
- Input Voltage
- 25.9 W
- Power Consumption SDR (On mode)
- 25.9 kWh/1000h
- Power Consumption HDR (On mode)
- 37.7 kWh/1000h
- Power Consumption (Max)
- 220 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.2 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.14 cm - depth: 18.5 cm - height: 38.518 cm - weight: 6.64 kg , Without stand - width: 61.14 cm - depth: 5.433 cm - height: 35.301 cm - weight: 4.48 kg
- Shipping Weight
- 9.53 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Premium Panel Exchange
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £150.16 |
Other bundles (4)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £148.13 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £28.06 |
Dell SB521A Magnetic Sound bar | In Stock | £30.21 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £57.27 |
