Stay productive, no matter where you work. Reduce harmful blue light with this sleek 23.8-inch FHD hub monitor with ComfortView Plus.
- Dell P2422HE - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class D
- Power Consumption (On mode)
- 14.5 W
- USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- 53.78 cm x 17.95 cm x 49.61 cm
- 6 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Designed For
- Latitude 5320, 5520; Precision 7560; Vostro 14 5410, 15 5510
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
- 53.78 cm x 17.95 cm x 49.61 cm - with stand
- 6 kg
- DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (MST) , HDMI (HDCP 1.4) , USB-C 3.1 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , 4 x USB 3.2 Gen 1 downstream , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m
- Input Voltage
- 14.5 W
- Power Consumption SDR (On mode)
- 14.5 kWh/1000h
- Power Consumption (Max)
- 118 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.2 Watt
- Dimensions & Weight Details
- Without stand - weight: 3.81 kg
- Shipping Weight
- 8.38 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell Vostro 14 5410, 15 5510
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £150.16 |
Other bundles (3)
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £28.06 |
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £141.12 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £57.27 |
