Dazzle your audience in the conference room and beyond with the palm-sized, multimedia Dell Mobile Projector M115HD with bright LED technology.
The conference room in your laptop bag
Take your presentations wherever you choose with the Dell Mobile Projector M115HD, the ideal travel companion for the mobile professional. -
Small and bright
You want the ultimate in brightness from your projector. Light up the room with the M115HD, featuring dazzlingly bright, colorful and crystal-clear projection. -
Total connectivity
Accept no limits when it comes to bringing media to your presentations. The M115HD features a remarkable amount of connectivity, giving you a wide range of media options to choose from. More than just a projector, the M115HD is truly a portable media hub for home and office.
- Dell Mobile Projector M115HD - DLP projector
- DLP projector - 720p
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 450 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- LED
- Bulb life cycle
- Up to 30000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
- Video Input
- RGB
- Supported Memory Cards
- microSD
- Storage Capacity
- 1 GB Flash
- Video Modes
- 480p, 720p, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 52 Watt
- 10.53 cm x 10.4 cm x 3.65 cm
- 360 g
- 1-year warranty
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 450 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 76 cm - 203 cm
- Projection Distance
- 0.97 m - 2.58 m
- Throw Ratio
- 1.5:1
- Uniformity
- 80 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb type
- LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, MobiShow technology, Mercury-free illumination technology, upgradable firmware
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.0
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI
- Video Modes
- microSD
Media Player
- Storage Capacity
- 1 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- Expansion Slots
- 1 x microSD
- 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x VGA - 24 pin universal I/O , 1 x VGA (on supplied cable)
- Included Accessories
- Carrying case
- Cables Included
- 1 x VGA cable
- Security Features
- Voltage Required
- 52 Watt
- Power Consumption Stand by
- 0.5 Watt
- 10.53 cm
- 10.4 cm
- 3.65 cm
- 360 g
- Limited warranty - lamp - 1 year , Limited warranty - 1 year
- 5 °C
- 35 °C
- 0 - 80%
- Sound Emission
- 36 dBA
- Sound Emission (Economic Mode)
- 32 dBA
