The essentials you need to be more productive. Get a wide viewing angle while saving desk space. This 21.5-inch Full HD monitor features height adjustability, built-in speakers and an eco-conscious design.
- Dell E2222HS - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class D
- Power Consumption (On mode)
- 12 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.249 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 3000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 10 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 50.426 cm x 18.728 cm x 35.417 cm
- 3.9 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
- 3-year warranty
- Bundled Services
- 3 Years Basic Hardware Service with Advanced Exchange after remote diagnosis - Disti SNS
- Designed For
- OptiPlex 3090; Vostro 14 5410, 15 5510
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.249 mm
- Pixel Per Inch
- 103
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Flicker Free technology, Dell ComfortView
- Black
- 50.426 cm x 18.728 cm x 35.417 cm - with stand
- 3.9 kg
Audio
- Speakers
- HDMI (HDCP 1.2) , DisplayPort 1.2 , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Included Accessories
- VESA screw cover
- Cables Included
- 1 x HDMI cable
- Input Voltage
- 12 W
- Power Consumption SDR (On mode)
- 12.1 kWh/1000h
- Power Consumption (Typical)
- 12.13 Watt
- Power Consumption (Max)
- 21 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 50.426 cm - depth: 18.728 cm - height: 35.417 cm - weight: 3.9 kg , Without stand - weight: 2.36 kg
- Shipping Weight
- 5.11 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited hardware warranty - 3 years
- Bundled Services
- Designed For
- Dell OptiPlex 3090 , Dell Vostro 14 5410, 15 5510
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £150.16 |
Other bundles (4)
Dell Slim DW316 USB External DVD Drive | In Stock | £32.24 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.74 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £28.06 |
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £141.12 |
