Brilliant screen clarity, environment-conscious design and rigorous reliability testing define the Dell 20 monitor E2014H.
Outstanding quality
Rigorous testing and process-quality monitoring help ensure long-term performance reliability. -
Environment-conscious
Built to comply with the latest environmental and regulatory standards. -
Energy-efficient design
With 14W normal-operation power consumption (typical) and less than 0.5W in active-off mode, the Dell 20 Monitor can help keep energy costs down, particularly in large deployments. Manage power consumption wisely with PowerNap, which you can enable through the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
- Dell E2014H - E Series - LED monitor - 19.45" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
- LED-backlit LCD monitor - 19.45"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 83% (CIE 1976)
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 47.39 cm x 16.55 cm x 35.88 cm
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, RoHS, CEL
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Diagonal Size
- 19.45"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 83% (CIE 1976)
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- 47.39 cm x 16.55 cm x 35.88 cm - with stand
- Bundled with
- DVI-D (HDCP) , VGA
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, VESA screw cover
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 47.39 cm - depth: 16.55 cm - height: 35.88 cm - weight: 3.14 kg , Without stand - width: 47.39 cm - depth: 4.65 cm - height: 27.63 cm - weight: 2.41 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
