A 23.8" monitor enhances your daily workflow. Featuring a height adjustable stand, Full HD resolution and integrated speakers in a space-saving design.
Adapts to any routine
Make your monitor your own with the height adjustable stand. Raise the stand or tilt the display for improved comfort and ergonomics. -
Amplify your work
Lose the sounds of your surroundings and focus on incoming notifications with the new integrated speakers. -
A flexible setup
Customize your workspace with VESA-compatible mounts and stands. -
Productive at every level
Dell Display Manager's (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you'll get even more preset layouts. -
Seamless transitions
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged. -
The key to convenience
Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster. -
More ways to manage
Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup. -
Work with a view
Your work will shine from any angle on this 24-inch display. Full HD resolution with In-Plane Switching (IPS) technology delivers consistent colors across the screen. -
Maximize your space
A thin profile, narrow bezel and improved cable management create a small footprint in a wide view, lending itself to a clean, uncluttered desk. -
Versatile connections
The E series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs. -
Ready for long days
ComfortView reduces up to 60% of harmful blue light emissions1 for extended viewing periods.
- Dell E2424HS - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class D
- Power Consumption (On mode)
- 14 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 3000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931), 83% NTSC (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 53.864 cm x 20.946 cm x 37.791 cm
- 4.53 kg
- Pricing Type
- Brown Box
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Bundled Services
- 3 years Advanced Exchange Service and Limited Hardware Warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Flicker-Less technology, Dell ComfortView, Low Blue Light technology, 3-sided bezeless
- 53.864 cm x 20.946 cm x 37.791 cm - with stand (lowest position)
- 4.53 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- DisplayPort 1.2 , VGA , HDMI
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 346
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Pricing Type
- Brown Box
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14 W
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 53.864 cm - depth: 20.946 cm - height: 37.791 cm - weight: 4.53 kg , With stand (highest position) - width: 53.864 cm - depth: 20.946 cm - height: 51.207 cm - weight: 4.53 kg , Without stand - width: 53.864 cm - depth: 4.89 cm - height: 32.421 cm - weight: 2.82 kg
- Shipping Weight
- 5.96 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
