Dell E Series E2424HS 23.8" 1920x1080 8ms VGA HDMI DisplayPort LED Monitor
Quicklinx: H7PXWS00 Mfr#: DELL-E2424HS
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, VGA (HD-15), HDMI
More than 50 In Stock
£100.86 ex VAT
£121.03 inc VAT
A 23.8" monitor enhances your daily workflow. Featuring a height adjustable stand, Full HD resolution and integrated speakers in a space-saving design.
  • Adapts to any routine
    Make your monitor your own with the height adjustable stand. Raise the stand or tilt the display for improved comfort and ergonomics.
  • Amplify your work
    Lose the sounds of your surroundings and focus on incoming notifications with the new integrated speakers.
  • A flexible setup
    Customize your workspace with VESA-compatible mounts and stands.
  • Productive at every level
    Dell Display Manager's (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you'll get even more preset layouts.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
  • Work with a view
    Your work will shine from any angle on this 24-inch display. Full HD resolution with In-Plane Switching (IPS) technology delivers consistent colors across the screen.
  • Maximize your space
    A thin profile, narrow bezel and improved cable management create a small footprint in a wide view, lending itself to a clean, uncluttered desk.
  • Versatile connections
    The E series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs.
  • Ready for long days
    ComfortView reduces up to 60% of harmful blue light emissions1 for extended viewing periods.
Dell E2424HS - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
14 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 3000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931), 83% NTSC (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.864 cm x 20.946 cm x 37.791 cm
4.53 kg
Pricing Type
Brown Box
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Flicker-Less technology, Dell ComfortView, Low Blue Light technology, 3-sided bezeless
53.864 cm x 20.946 cm x 37.791 cm - with stand (lowest position)
4.53 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DisplayPort 1.2 , VGA , HDMI
Mechanical
Tilt Angle
-5/+21
Swivel Angle
346
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Pricing Type
Brown Box
Security Slot Type
Kensington security slot
Input Voltage
14 W
14 kWh/1000h
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Dimensions & Weight Details
With stand (lowest position) - width: 53.864 cm - depth: 20.946 cm - height: 37.791 cm - weight: 4.53 kg , With stand (highest position) - width: 53.864 cm - depth: 20.946 cm - height: 51.207 cm - weight: 4.53 kg , Without stand - width: 53.864 cm - depth: 4.89 cm - height: 32.421 cm - weight: 2.82 kg
Shipping Weight
5.96 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 5ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: Dell
