D-Link Wireless N Router DIR-615- For Cable Users
Quicklinx: 4Q20WS00 Mfr#: DIR-615/B
  • IEEE 802.11n
With the latest firmware installed, you will be able to turn off the router's wireless signal altogether at certain times of the day, to save energy.
The DIR-615 Wireless N Home Router connects to any modem or ISP box to provide Internet access for computers and other network equipment.
Wireless N technology offers more speed, extended coverage and virtually no dead spots while still compatible with previous network standards. This router transfers data at speeds of up to 300 Mbps.
Setting the router up is easy even for non-technically minded people, with D-Link Click'n Connect: run directly from the product CD-ROM, this wizard takes you through an interactive step-by-step guide that will get you on-line in a matter of minutes. It also includes a simplified method of setting up wireless encryption, the WiFi Wireless Protect Setup (WPS), which works at the touch of a button.
A powerful dual firewall (SPI and NAT) prevents Denial of Service (DoS) attacks and attempts to breach your network from the Internet. You can also define a list of allowed sites to restrict web access during certain periods.
D-Link Wireless N DIR-615 - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, NTP, IPSec, PPPoE, DHCP
Remote Management Protocol
HTTP
Full duplex capability, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, MAC address filtering, VPN passthrough, IP address filtering, QoS, WPS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
12.7 cm x 19.8 cm x 3.1 cm
272 g
Microsoft Certification
Compatible with Windows 7
Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista, Microsoft Windows XP SP3
United Kingdom, Ireland
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
HTTP
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, FCC Class B certified, IC
Status Indicators
Port status, power, status
Line Properties
Line Coding Format
CCK, OFDM
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
2 dBi
External power adapter
1 x network cable
Additional Requirements
CD-ROM
12.7 cm
19.8 cm
3.1 cm
272 g
10 - 95%
Resources
The following resources are available for the D-Link Wireless N Router DIR-615- For Cable Users
