The Wireless N 150 ADSL2+ Modem Router is a versatile, high-performance remote router for home and the small office. With integrated ADSL2/2+, firewall protection, Quality of Service (QoS), 802.11n wireless LAN and 2 Ethernet switch ports, this router provides all the functions that a home or small office needs to establish a secure and high-speed remote link to the outside world.
The Wireless N 150 ADSL2+ Modem Router provides wireless speeds that are many times faster than 802.11g. Maximize wireless performance and stay connected from virtually anywhere at home and in the office. The DSL-2680 supports WPA/WPA2 and WEP data encryption methods for flexible user access security. The Wireless N 150 ADSL2+ Modem Router is backward compatible with existing 802.11b and 802.11g wireless equipment, ensuring compatibility with a wide range of wireless devices.
Security features prevent unauthorized access to the home and office network from wireless devices or from the Internet. The Wireless N 150 ADSL2+ Modem Router provides firewall security, such as Stateful Packet Inspection (SPI) and hacker attack logging. SPI inspects the content of incoming packets before they are allowed in, while hacker logging helps to protect your network against Denial of Service (Dos) attacks.
High-speed Internet
The Wireless N 150 ADSL2+ Modem Router is a versatile, high-performance remote router for home and the small office. With integrated ADSL2/2+, firewall protection, Quality of Service (QoS), 802.11n wireless LAN and 2 Ethernet switch ports, this router provides all the functions that a home or small office needs to establish a secure and high-speed remote link to the outside world. -
Ultimate wireless connection
The Wireless N 150 ADSL2+ Modem Router provides wireless speeds that are many times faster than 802.11g. Maximize wireless performance and stay connected from virtually anywhere at home and in the office. The DSL-2680 supports WPA/WPA2 and WEP data encryption methods for flexible user access security. The Wireless N 150 ADSL2+ Modem Router is backward compatible with existing 802.11b and 802.11g wireless equipment, ensuring compatibility with a wide range of wireless devices. -
Full featured security suite
Security features prevent unauthorized access to the home and office network from wireless devices or from the Internet. The Wireless N 150 ADSL2+ Modem Router provides firewall security, such as Stateful Packet Inspection (SPI) and hacker attack logging. SPI inspects the content of incoming packets before they are allowed in, while hacker logging helps to protect your network against Denial of Service (Dos) attacks. -
High-speed ADSL and wireless performance
Connect to your ADSL connection at up to 24 Mbps downstream and 1 Mbps upstream. High speed performance gives you smooth media streaming, so you can watch TV, listen to live music, broadcast over the Internet, and experience clear Internet phone calls. Wireless N 150 technology allows you to connect to 802.11n wireless devices, so you can make full use of your broadband connection.
- D-Link DSL-2680 - wireless router - DSL modem - 802.11b/g/n - desktop
- Wireless router - DSL modem - 2-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
- 150 Mbps
- PPTP, L2TP, IPSec, PPPoE, PPPoA, DHCP
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- NAT support, Stateful Packet Inspection (SPI), packet filtering, dynamic DNS server, Intrusion Detection System (IDS), VPN passthrough, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, DNS proxy
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
- 11.3 cm x 14.8 cm x 3.2 cm
- Wireless router - 2-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 150 Mbps
- Routing Protocol
- Status Indicators
- Port status
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.992.5 Annex L
- WAN: 1 x ADSL2+ - RJ-11 , LAN: 2 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 1
- Power Device
- External power adapter
- 11.3 cm
- 14.8 cm
- 3.2 cm
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
