D-Link DIS 200G 12-Ports Managed Gigabit Ethernet Switch
Quicklinx: F3XWWS00 Mfr#: DIS-200G-12PS
Type: Gigabit Ethernet
Ports: 10
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE+
£586.12 ex VAT
£703.34 inc VAT
The DIS-200G-12PS Layer 2 Industrial Managed Switch is equipped with 8 PoE-capable 10/100/1000BASE-T ports, 2 10/100/1000BASE-T ports, and 2 SFP ports. This switch features a robust design making it ideal for deployment in industrial and outdoor surveillance settings, capable of withstanding the harshest environments. The DIS-200G-12PS furthermore integrates advanced management and security functions to provide a complete solution.
  • Durable and reliable design
    The DIS-200G-12PS switch is housed in a highly resistant IP30-rated metal casing to protect the switch from harsh environmental conditions. The high electromagnetic compatibility (EMC) protects DIS-200G-12PS from unwanted effects when operating in environments with strong electromagnetic interference. Meanwhile, the fanless design extends the life of DIS-200G-12PS while also being able to operate in a wider temperature range of up to 65 °C. For increased flexibility, the DIS-200G-12PS switch can also be mounted on a DIN rail, wall mounted, or be installed in an equipment rack. Additionally, the DIS-200G-12PS switch features 6 kV surge protection on all copper ports to help prevent damage to the switch and connected devices caused by sudden power surges and lightning strikes. The in-built surge protection of up to 6 kV can mitigate the damage to the switch from both indoor and outdoor devices and network connections by absorbing the excess energy while still letting the amount of power through required for the switch to operate normally. This increases network reliability, reduces repair costs, and removes the need for replacement hardware in the event of an electrical surge or lightning strike.
  • High redundancy and reliability
    The DIS-200G-12PS switch supports ERPS quick failover recovery for ring topologies that ensures minimal downtime and avoids any loss of data in mission-critical deployment settings. Meanwhile, the dual power input allows for a redundant power supply to make sure the network continues to operate in the event of a primary power supply failure.
  • Surveillance traffic optimization
    The DIS-200G-12PS switch supports the Auto Surveillance VLAN feature. This automatically detects surveillance devices and puts them into a dedicated surveillance VLAN, segmenting their traffic from the rest of the network. This provides increased security of surveillance data, and gives the traffic a higher priority through the switch, reducing the chances of the video freezing or being delayed on live streams. A single switch can be used for both surveillance and data networks, removing the need for dedicated surveillance hardware while simultaneously reducing maintenance costs.
  • Easy troubleshooting
    The DIS-200G-12PS switch features loopback detection and cable diagnostics to help network administrators find and solve network problems quickly and easily. Loopback detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable diagnostics helps network administrators quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
D-Link DIS 200G-12PS - switch - 10 ports - Managed
Switch - 10 ports - Managed
Subtype
Gigabit Ethernet
Ports
10 x 10/100/1000 (8 PoE+) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Switching capacity: 24 Gbps , Throughput (64-byte packet size): 17.85 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
Telnet, CLI
Flow control, ARP support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, SNTP support, STP support, RSTP support, MSTP support, QoS, MLD snooping, Safeguard Engine, reset button, Cable Diagnostics Function, IPv4 support, fanless, LLDP support, LACP, Port Security, SNMP trap, DHCP client, 512KB packet buffer, GVRP, dual firmware images, SP, tagged VLAN, TFTP client, 802.1x authentication, ERPS, DDM, AAA, WAC, EEE, WRR, HOL Blocking Prevention, loopback detection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
AC 120/230 V / DC 46 - 54 V (50/60 Hz)
21 cm x 17.12 cm x 4.8 cm
2.5 kg
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
240 W
Performance
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Telnet, CLI
Encryption Algorithm
SSL
Authentication Method
RADIUS
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Status
10 x 1000Base-T RJ-45 8 ports (PoE+) - 30 W , 2 x 1000Base-X SFP , 1 x console RJ-45
260 Watt
DIN-rail mounting kit, wall mounting kit
1 x console cable
MTBF
205 689 hours
UL, C-Tick, BSMI, IEC 61000-4-5, FCC, IP30
Software Included
Drivers & Utilities
21 cm
17.12 cm
4.8 cm
2.5 kg
-40 °C
65 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Humidity Range Storage
Ports: 10
Managed: Yes
POE: PoE+
Brand: D-Link
Price Range Ex VAT: £500 - £750
