D-Link AirPremier 108AG Wireless Switch Access Point
Quicklinx: 5DJ1WS00 Mfr#: DWL-8500AP
DWL-8500AP Wireless Switching 108 AG Access Point is a high-performance wireless access device that provides up to 108Mbps transmission rates and flexible dualband wireless connectivity. The DWL-8500AP delivers concurrent wireless performance with maximum wireless signal rates in both frequency bands simultaneously. With dualband connectivity, two wireless networks are created both running at full bandwidth speeds, offering a significant increase in total network capacity. At the same time, the DWL-8500AP remains fully backward compatible with the 802.11b standard in the 2.4GHz frequency.
With transmission speeds of up to 108Mbps (Turbo mode) on both frequency bands, the DWL-8500AP is an ideal solution for bandwidth intensive WLAN application. In a typical working environment with multiple users accessing the network at the same time, the DWL-8500AP can operate at double times the throughput of regular 802.11g wireless LAN equipment.
For maximum coverage, the DWL-8500AP can be placed at out-of-the-way locations such as on a ceiling or a high wall, where AC outlets are inaccessible and providing power to these locations is difficult and expensive.
DWL-8500AP plays a key role in rogue detection. It continuously scans both frequency bands and their associated channels to root out rogues while simultaneously providing wireless connectivity to mobile clients. If a rogue is detected, the closest DWL-8500AP can launch RF counter measures by spoofing 802.11 control messages. This prevents clients from communicating, associating and authenticating with a rogue.
D-Link AirPremier AG DWL-8500AP Wireless Switching 108 AG Dualband Access Point - radio access point - Wi-Fi
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Power Over Ethernet (PoE) Supported
PoE
15.5 cm x 4.5 cm x 27.8 cm
0.8 kg
Radio access point
Ruggedized Design
Indoor
15.5 cm
4.5 cm
27.8 cm
0.8 kg
External
Wireless
Data Transfer Rate
108 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
SNMP 1, RMON 1, Telnet, SNMP 3, SNMP 2c, HTTP
Status Indicators
Power, status
MAC address filtering, Turbo Mode, Zero Configuration Technology, Wi-Fi Multimedia (WMM) support
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.3x, IEEE 802.11g, IEEE 802.1x
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 100Base-TX (PoE) - RJ-45
FCC Class B certified, UL, VCCI, C-Tick
PoE
10 - 90%
