D-Link 24-Port Desktop Gigabit PoE + 2GE Combo Switch
Quicklinx: D0X2WS00 Mfr#: DGS-1026MP
Type: Gigabit Ethernet
Ports: 26
Data Transfer Rate: [N/A]
Managed: No
POE: PoE
49 In Stock
£248.81 ex VAT
£298.57 inc VAT
The D-Link DGS-1026MP 26-Port Gigabit Max PoE Switch enables users to easily connect and power PoE-capable devices such as wireless access points (APs), IP cameras, and IP phones. Each of the 24 PoE ports can supply up to 30 W, with a total PoE budget of 370 W.
  • Power over Ethernet
    The DGS-1026MP features 24 10/100/1000Base-T ports, that support the IEEE 802.3at PoE+ standard. Each of the 24 PoE ports can supply optimal power, with a high total PoE budget. The PoE usage LEDs further provide real-time feedback on the current PoE power usage on the network and help plan out the PoE network budget, preventing PoE overloading problems.
  • Expand your network
    The addition of two Gigabit combo uplink ports means businesses can increase their network bandwidth, using the speed of Gigabit Ethernet, while offering redundancy, so voice and surveillance data are transferred reliably.
  • Energy efficient
    To help small businesses save on operating costs, the DGS-1026MP supports IEEE 802.3az Energy Efficient Ethernet (EEE). This feature actively monitors network traffic and automatically puts ports, that are not being used into hibernation, powering them on, only when they are required.
  • Hassle-free setup
    The DGS-1026MP is a Plug and Play device, that requires no configuration, so setup is simple and hassle-free. Simply connect the switch to the network and then connect multiple computers, share files and make VoIP calls across the network.
D-Link DGS 1026MP - switch - 26 ports - unmanaged - rack-mountable
Switch - 26 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
370 W
Performance
Switching capacity: 52 Gbps , Forwarding performance (64-byte packet size): 38.69 Mpps
MAC Address Table Size
8K entries
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
25.04 cm x 44 cm x 4.4 cm
3.1 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
370 W
Performance
8K entries
Status Indicators
Port transmission speed, power, fail, PoE, link/activity
24 x 1000Base-T RJ-45 PoE - 30 W , 2 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP
Internal power supply
Rack Mounting Kit
Included
MTBF
205,975 hours
FCC Class A certified, VCCI, BSMI, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, RCM
25.04 cm
44 cm
4.4 cm
3.1 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Ports: 26
Managed: No
POE: PoE
Brand: D-Link
